Home » Eclipse Projects » Eclipse Platform » Positioning of Items in Toolbar/Coolbar
Positioning of Items in Toolbar/Coolbar [message #332916] Thu, 13 November 2008 15:17 Go to next message
I need to add an Action to the end of a toolbar (rightmost position).
Somebody knows here how to control the positioning of elements on the
toolbar/coolbar?
Can I add one action to the leftmost position and another to the rightmost
positon?
Thanks in advance.
Marcelo
Re: Positioning of Items in Toolbar/Coolbar [message #332930 is a reply to message #332916] Fri, 14 November 2008 09:36 Go to previous messageGo to next message
No hints on this issue?
Thanks again.
Marcelo
"Marcelo Alcantara" <marcelo.alcantara@cshg.com.br> escreveu na mensagem
news:gfi20d$flo$1@build.eclipse.org...
> toolbar/coolbar?
> positon?
> Thanks in advance.
> Marcelo
Re: Positioning of Items in Toolbar/Coolbar [message #333050 is a reply to message #332916] Fri, 21 November 2008 14:57 Go to previous messageGo to next message
you need to have something in their already, a well known ID, and then
use that.
PW
Paul Webster
Re: Positioning of Items in Toolbar/Coolbar [message #333064 is a reply to message #333050] Mon, 24 November 2008 07:33 Go to previous messageGo to next message
Hi Paul,
Thank you very much for your reply.
It is possible, somehow, to add an action to the leftmost location and
another one on the rightmost location as an example?
Thanks again.
Marcelo
"Paul Webster" <pwebster@ca.ibm.com> escreveu na mensagem
news:gg74a4$q81$1@build.eclipse.org...
> you need to have something in their already, a well known ID, and then use
> that.
> PW
> Paul Webster
Re: Positioning of Items in Toolbar/Coolbar [message #333070 is a reply to message #333064] Mon, 24 November 2008 08:40 Go to previous messageGo to next message
Marcelo Alcantara wrote:
> Hi Paul,
> Thanks again.
> Marcelo
Yes, if you have a well known ID already at the leftmost position and
use after=<well known ID>
PW
Paul Webster
Re: Positioning of Items in Toolbar/Coolbar [message #333401 is a reply to message #333070] Tue, 09 December 2008 11:30 Go to previous messageGo to next message
Aha. So how does one get an ID at that (or some other) position of the toolbar or the statusbar? Can
this also be done e.g. with trims to place a contribution at the top, the bottom
or the center of a trim?
MH
Re: Positioning of Items in Toolbar/Coolbar [message #333404 is a reply to message #333401] Tue, 09 December 2008 13:13 Go to previous message
> toolbar or the statusbar? Can this also be done e.g. with trims to place
As it depends on the set of features loaded, you can't really know ...
if you are an RCP app you can control what goes into the trim/status and
so place things exactly. If you are simply a plugin, you have to set a
breakpoint and find out which ID is at the end.
PW
Paul Webster
Previous Topic:IApplication class loader problem
Next Topic:Managing fonts
Current Time: Tue Oct 14 21:57:08 EDT 2025
Powered by FUDForum. Page generated in 0.04531 seconds
