Home » Eclipse Projects » Eclipse Platform » [Commands Framework] differentiating between view popup and toolbar
[Commands Framework] differentiating between view popup and toolbar [message #332913] Thu, 13 November 2008 14:34 Go to next message
I have a command that I want to handle in two different ways from the
view toolbar and the popup menu. From the toolbar, I want it to apply
to all items in the view (TableViewer). From the popup menu, I want it
to apply to the selection.
Is there a way to do this? I think that I would either need a way to
differentiate the context from a single handler or have two handlers and
differentiate through the handler enablement in plugin.xml. I can not
figure out how to do either.
Any suggestions?
Will
Re: [Commands Framework] differentiating between view popup and toolbar [message #332923 is a reply to message #332913] Fri, 14 November 2008 04:10 Go to previous messageGo to next message
Won't that behaviour would be little confusing for the user? Whats wrong
with having two different commands? Something like "Mark as Read" and "Mark
all as Read" in the mail clients. Personally I would prefer that way rather
than "Mark as Read" command works on selection if invoked from popup and
works on all elements if invoked from toolbar.
- Prakash
http://blog.eclipse-tips.com
"Will Horn" <will.horn@gmail.com> wrote in message
news:gfhvgo$3e1$1@build.eclipse.org...
> I have a command that I want to handle in two different ways from the view
> toolbar and the popup menu. From the toolbar, I want it to apply to all
> items in the view (TableViewer). From the popup menu, I want it to apply
> to the selection.
> Any suggestions?
> Will
Re: [Commands Framework] differentiating between view popup and toolbar [message #332941 is a reply to message #332923] Fri, 14 November 2008 16:34 Go to previous message
> "Mark all as Read" in the mail clients. Personally I would prefer that
> way rather than "Mark as Read" command works on selection if invoked
> from popup and works on all elements if invoked from toolbar.
Fair enough :) I was planning to label them differently (in my case it
would be "Stop" and "Stop All") since I can do that when I contribute to
org.eclipse.ui.menus. But two commands is reasonable and would
prevent any potential accidents if there are key bindings.
Previous Topic:getConfiguredSites() method retuning an empty array
Next Topic:OleEditor for embedded editors doesn't work in RCP application
Current Time: Fri Jul 18 19:02:01 EDT 2025
Powered by FUDForum. Page generated in 0.06006 seconds
