Re: How can I get notified when java build path is changed [message #332929 is a reply to message #332917] |
Fri, 14 November 2008 09:28  |
On 11/13/2008 3:25 PM, Raymond wrote:
> Eric Rizzo wrote:
>> I would get the IJavaProject associated with the resource change event
>> [see org.eclipse.jdt.core.JavaCore.create(IProject)] and then see if
>> you can inspect its build path through the IJavaProject API.
>> Does the resource delta include the .classpath file? I'd expect it
>> would; that way you can distinguish changes that affect build path
>> from other project changes.
>> Hope this helps,
>> Eric
> Thanks for your reply, Eric.
> Implementing a resource change listener is what I do now. The .classpath
> file is in the change delta but as what I said, I only know the file is
> changed but I don't know what the change is. I need more specific
> information. I want to know what is added/removed to/from the java build
> path.
I don't think there is any notification API at that level; that's why I
suggested getting the IJavaProject from the IProject in the delta.
You might have better luck by posting the question to the
eclipse.tools.jdt newsgroup; maybe the JDT gurus there know of an
alternative API that would help.
Eric
FUDForum. Page generated in 0.04343 seconds
