Home » Eclipse Projects » Eclipse Platform » How can I get notified when java build path is changed
How can I get notified when java build path is changed [message #332909] Thu, 13 November 2008 11:47 Go to next message
Hey,
My plug-in wants to be notified when the java build path of a project is
changed. How can it get notified? is there any property change listener I
can implement? Thanks.
Re: How can I get notified when java build path is changed [message #332910 is a reply to message #332909] Thu, 13 November 2008 11:54 Go to previous messageGo to next message
To be more specific, if the java build path of a project is changed, I
want to know what the change is (e.g. what jar/project/folder is
added/removed to/from the class path).
Re: How can I get notified when java build path is changed [message #332911 is a reply to message #332910] Thu, 13 November 2008 12:03 Go to previous messageGo to next message
I know a change of java build path invokes a resource change event but
through resource change listener, I can only know the project is changed
but I have no idea what the change is.
Re: How can I get notified when java build path is changed [message #332915 is a reply to message #332911] Thu, 13 November 2008 14:42 Go to previous messageGo to next message
I would get the IJavaProject associated with the resource change event
[see org.eclipse.jdt.core.JavaCore.create(IProject)] and then see if you
can inspect its build path through the IJavaProject API.
Does the resource delta include the .classpath file? I'd expect it
would; that way you can distinguish changes that affect build path from
other project changes.
Hope this helps,
Eric
Re: How can I get notified when java build path is changed [message #332917 is a reply to message #332915] Thu, 13 November 2008 15:25 Go to previous messageGo to next message
> Hope this helps,
> Eric
Thanks for your reply, Eric.
Implementing a resource change listener is what I do now. The .classpath
file is in the change delta but as what I said, I only know the file is
changed but I don't know what the change is. I need more specific
information. I want to know what is added/removed to/from the java build
path.
Thanks.
Re: How can I get notified when java build path is changed [message #332929 is a reply to message #332917] Fri, 14 November 2008 09:28 Go to previous message
>> you can inspect its build path through the IJavaProject API.
>> from other project changes.
>> Hope this helps,
>> Eric
> path.
I don't think there is any notification API at that level; that's why I
suggested getting the IJavaProject from the IProject in the delta.
You might have better luck by posting the question to the
eclipse.tools.jdt newsgroup; maybe the JDT gurus there know of an
alternative API that would help.
Eric
Previous Topic:How to sort the preferences pages ?
Next Topic:Help Files Offline
Current Time: Sat Aug 30 23:53:27 EDT 2025
Powered by FUDForum. Page generated in 0.07662 seconds
