MQTTDataTransport lost connection [message #1774273] |
Thu, 12 October 2017 12:20 |
Thinh Nguyen Messages: 1 Registered: October 2017 |
I have a raspeberry pi3 running raspbian kernel 4.4.21-v7 and Eclipse Kura 1.3.0. It collects data from sensors (temp, humid...) and publishs to broker every 60 seconds, on the server side there is a java class that will listen to that topic and log it.
Everything is running good except every 60 minutes (±30s) the java class stop receiving payload but when i check the kura log of the raspberry, its still publishing payload as normal. And around 15 minutes later, kura will log this message
2017-10-12 18:06:59,730 [MQTT Ping: B8:27:EB:E8:53:82] WARN o.e.k.c.d.t.m.MqttDataTransport - Connection Lost
Timed out waiting for a response from the server (32000)
at org.eclipse.paho.client.mqttv3.internal.ExceptionHelper.createMqttException(ExceptionHelper.java:31)
at org.eclipse.paho.client.mqttv3.internal.ClientState.checkForActivity(ClientState.java:564)
at org.eclipse.paho.client.mqttv3.internal.ClientComms.checkForActivity(ClientComms.java:660)
at org.eclipse.paho.client.mqttv3.TimerPingSender$PingTask.run(TimerPingSender.java:77)
at java.util.TimerThread.mainLoop(Timer.java:555)
at java.util.TimerThread.run(Timer.java:505)
2017-10-12 18:06:59,732 [MQTT Ping: B8:27:EB:E8:53:82] INFO o.e.k.c.d.DataServiceImpl - connectionLost
2017-10-12 18:06:59,733 [pool-16-thread-1] INFO o.e.k.l.s.r.LogStatusRunnable - Notification LED slow blinking
2017-10-12 18:06:59,733 [MQTT Ping: B8:27:EB:E8:53:82] INFO o.e.k.c.d.DataServiceImpl - Starting reconnect task with initial delay 11
2017-10-12 18:06:59,734 [MQTT Ping: B8:27:EB:E8:53:82] WARN o.e.k.c.Cloudlet - Cloud Client Connection Lost!
2017-10-12 18:06:59,735 [MQTT Ping: B8:27:EB:E8:53:82] WARN o.e.k.c.Cloudlet - Cloud Client Connection Lost!
2017-10-12 18:06:59,735 [MQTT Ping: B8:27:EB:E8:53:82] INFO o.e.k.c.d.CloudDeploymentHandler - connectionLost
2017-10-12 18:06:59,736 [MQTT Ping: B8:27:EB:E8:53:82] WARN o.e.k.c.Cloudlet - Cloud Client Connection Lost!
2017-10-12 18:06:59,736 [MQTT Ping: B8:27:EB:E8:53:82] WARN c.g.i.g.a.i.ActuatorImpl - Cloud Client Connection Lost!
Then Kura will start reconnect to broker and after 60 minutes it happens again.
Any ideas are welcome.
Thanks and best regard
Please pardon my English
FUDForum. Page generated in 0.03314 seconds
