Home » Eclipse Projects » Eclipse Platform » question about resource traversal in eclipse
question about resource traversal in eclipse [message #332872] Tue, 11 November 2008 17:18 Go to next message
Originally posted by: marc.esher.comcast.net
Greetings all,
What's the preferred method of traversing resources in eclipse, i.e. user
right clicks on a directory, selects menu item to perform some action on
each resource in that directory and all subdirs? I'd like to simply get a
List of all resources for a dir and its subdirs. Just checking to see what's
built into the framework before going down the recursion route.
thanks!
marc
Re: question about resource traversal in eclipse [message #332876 is a reply to message #332872] Wed, 12 November 2008 01:26 Go to previous messageGo to next message
You need to create a IResourceVisitor and call the IFolder.accept() method
- Prakash
http://blog.eclipse-tips.com
Re: question about resource traversal in eclipse [message #332896 is a reply to message #332876] Wed, 12 November 2008 22:03 Go to previous messageGo to next message
awesome. that was what i was hoping to hear.
is this "idiom" documented with examples anywhere? the reason I ask is that
in order to even learn this was a possible approach, I basically stumbled
through other people's code that appeared to do something similar to what i
want to do, and that seemed awfully inefficient to me. I wasn't able to find
any non-API documentation on this though.
thanks.
marc
"Prakash G.R." <grprakash@gmail.com> wrote in message
news:gfdsvi$7da$1@build.eclipse.org...
> - Prakash
Re: question about resource traversal in eclipse [message #332914 is a reply to message #332896] Thu, 13 November 2008 14:35 Go to previous messageGo to next message
> that in order to even learn this was a possible approach, I basically
> stumbled through other people's code that appeared to do something
> similar to what i want to do, and that seemed awfully inefficient to me.
> I wasn't able to find any non-API documentation on this though.
The book "Contributing to Eclipse" by Gamma and Beck has a section on it
(here's the Google Books link:
http://books.google.com/books?id=0X6wZRd5OOQC&pg=PA301&a mp;lpg=PA301&dq=eclipse+resource+visitor)
This article (available on the Resources page of www.eclipse.org) talks
about it in the context of resource change events:
http://www.eclipse.org/articles/Article-Resource-deltas/reso urce-deltas.html
Personally, I work with a full SDK build of Eclipse so all of the
platform and "core" plugins have source included. That way I can easily
find uses of any API that I'm interested in to look at for examples.
Hope this helps,
Eric
>> method
>> - Prakash
Re: question about resource traversal in eclipse [message #332918 is a reply to message #332914] Thu, 13 November 2008 16:08 Go to previous messageGo to next message
that helps a lot, Eric. I find that once I realize "the Eclipse way", I'm
often struck by how simple things are. It's finding "the way" that hangs me
up a lot.
thanks.
Marc
"Eric Rizzo" <eclipse-news@rizzoweb.com> wrote in message
news:gfhvim$3vt$1@build.eclipse.org...
> Personally, I work with a full SDK build of Eclipse so all of the platform
> and "core" plugins have source included. That way I can easily find uses
> Hope this helps,
> Eric
>>> method
>>> - Prakash
Re: question about resource traversal in eclipse [message #332925 is a reply to message #332918] Fri, 14 November 2008 04:31 Go to previous message
<shameless advertisement>
Give my Google Custom Search a try. Next time you might find it a little
easier to search for :-)
http://blog.eclipse-tips.com/2008/02/eclipse-search.html
http://blog.eclipse-tips.com/2008/07/eclipse-search-now-with -firefox-plugin.html
</shameless advertisement>
- Prakash
"Marc E" <marc.esher@comcast.net> wrote in message
news:gfi50p$imm$1@build.eclipse.org...
> me up a lot.
> thanks.
> Marc
>> Hope this helps,
>> Eric
>>>> method
>>>> - Prakash
Previous Topic:How to change icon based on content in Project Explorer
Next Topic:Key bindings / Listen for changes
Current Time: Wed Nov 05 04:26:10 EST 2025
Powered by FUDForum. Page generated in 0.26671 seconds
