Home » Eclipse Projects » Eclipse Platform » Delete/Purge old plugins
Delete/Purge old plugins [message #332816] Mon, 10 November 2008 12:44 Go to next message
Hi!
Is there a way to delete all plugins from the eclipse installation which
have been replaced by newer versions? Google did not come up with anything
useful apart from deleting them manually.
Florian
DI Florian Hackenberger
florian@hackenberger.at
www.hackenberger.at
Re: Delete/Purge old plugins [message #332830 is a reply to message #332816] Mon, 10 November 2008 16:50 Go to previous messageGo to next message
On 11/10/2008 12:44 PM, DI Florian Hackenberger wrote:
> Hi!
No, manual is the only way.
By the way, the old versions are kept around for good reasons, so you
may not want to go deleting them. For example, to enable the feature
that lets you revert to a previous configuration in the case that your
current one gets broken. Also, plugins can specify that they require a
specific version range of other plugins, so it is quite possible that
older versions need to be kept around to satisfy other plugins.
Hope this helps,
Eric
Re: Delete/Purge old plugins [message #332834 is a reply to message #332830] Mon, 10 November 2008 17:10 Go to previous messageGo to next message
Originally posted by: zx.code9.com
>> Hi!
>> anything
In Eclipse 3.4, this has changed with p2 and its GC. By default,
plug-ins who have no dependents will be GC'd.
~ Chris
Re: Delete/Purge old plugins [message #332866 is a reply to message #332834] Tue, 11 November 2008 11:37 Go to previous message
On 11/10/2008 5:10 PM, Chris Aniszczyk wrote:
>>> Hi!
>>> anything
Cool. But I'm curious how the "revert configuration" feature can work if
old plug-ins are removed. Would that scenario trigger re-download of the
GCed plug-ins?
Eric
Previous Topic:Outline view default to collapse?
Next Topic:How to find dependencies of plug-in?
Current Time: Sun Jul 27 01:36:02 EDT 2025
Powered by FUDForum. Page generated in 0.03138 seconds
