Syntax for relative DOS path in 'Build command' string [message #1772982] |
Tue, 19 September 2017 16:10 |
Missing name Mising name Messages: 35 Registered: September 2010 |
Member |
Eclipse is an awesome IDE/Build Tool! I've been using Eclipse since Kepler. Currently using Oxygen 4.7.1RC4 on Windows 7 64-bit.
Refer to the attached PNG of the Project Properties Dialog.
I've avoided specifying a DOS path in the 'Build command' text because I not been able to get Eclipse to recognize the relative or absolute path. However, I now find myself finally needing understand how to specify a DOS path in the 'Build command' string.
I've tried ALL the combinations which are valid on a Windows 7 machine. I've googled for any hint of a solution, to no avail.
Major System Configuration:
Windows 7 64-bit
Eclipse IDE for C/C++ Developers
v 4.6.2 (Neon)
v 4.7.3a (Oxygen)
v 4.8r (Photon)
v 2018_09
PyDev
MinGW
MSys
GNU Toolchain
Perforce
FUDForum. Page generated in 0.02799 seconds
