Switch Workspace working [message #332737] |
Fri, 07 November 2008 00:57  |
I am using eclipse 3.4 for my IDE.
There is an option called "Switch Worksapce" in the "File" menubar , in
which if we give the path of any workspace ,it closes the previous
workspace and opens the new workspace.
But if we give the path of same workspace which is already opened it
stills closes that workspace and reopens the same workspace.
Is this really required if the previous workspace and new workspace is
same ?
Before closing and reopening , it should first check if the new workspace
is same as already opened workspace , if not same , then only close and
open the workspace.
Please look into this.
Sheela
Re: Switch Workspace working [message #332748 is a reply to message #332737] |
Fri, 07 November 2008 08:55  |
On 11/7/2008 12:57 AM, Sheela wrote:
> same ?
> workspace is same as already opened workspace , if not same , then only
> close and open the workspace.
If you think something is a bug or can be improved, you need to enter it
into Bugzilla: https://bugs.eclipse.org/bugs
Eric
FUDForum. Page generated in 0.10533 seconds
