Home » Eclipse Projects » Eclipse Platform » Replacing the splash image (via an update)
| Replacing the splash image (via an update) [message #332695] |
Wed, 05 November 2008 09:27  |
Originally posted by: subs._nospam_consertum.com
In our application, we provide our own splash image. This is working
fine. We are now wish to update the splash image via the update mechanism.
The splash image is located in our branding plugin, and we successfully
update the plugin (with the new image), but when Eclipse restarts, the
old image is still shown.
I noticed the image seemed to be cached in
eclipse/configuration/org.eclipse.equinox.launcher/com.xxx.b randing.nnnnn/splash.bmp
so I deleted it - but still the old image is loaded.
Any ideas how I can replace it?
Config:
Eclipse 3.3.1
Windows XP
Java 1.6
Derek
| Re: Replacing the splash image (via an update) [message #332701 is a reply to message #332695] |
Wed, 05 November 2008 16:39   |
How are you specifying the splash bmp to use?
-showsplash in the eclipse.ini file?
osgi.splashLocation in config.ini ?
osgi.splashPath in config.ini?
Both of -showsplash and osgi.splashPathwill do a search in the plugins
folder disk for the given bundle and will choose the highest version.
(-showsplash org.eclipse.platform or
osgi.splashPath=base:/plugins/org.eclipse.platform).
-showplash with a full path, or osgi.splashLocation point directly to
the bmp.
If you are using the old update which is unable to update the
eclipse.ini or config.ini, the way to get an updated splash screen is to
make sure you use splashPath or -showsplash to do a search.
Even if you are using p2, it is easiest to do it this way, unless you
craft p2 metadata to adjust the splash location directly.
It should not be necessary to clean the cache, as the bitmap is only
saved there after the location has been chosen and if we need to extract
the bitmap out of a jar.
-Andrew
Derek wrote:
> Config:
> Eclipse 3.3.1
> Windows XP
> Java 1.6
> Thanks
| Re: Replacing the splash image (via an update) [message #332703 is a reply to message #332701] |
Thu, 06 November 2008 03:41   |
Hi Andrew,
Thanks for the reply.
I am already using both -showsplash in the eclipse.ini and
osgi.splashPath in the config.ini:
osgi.splashPath=platform:/base/plugins/com.company.product.b rand
I have found that after the update, it is still showing the original
splash image. If I rename the plugin containing the original image, then
no splash is shown, even though there is a newer version of the plugin
installed.
Something, somewhere has a hard-coded link to the exact version number
of the branding plugin - but I can't find it... Any further ideas?
> the bmp.
> -Andrew
> Derek wrote:
>> mechanism.
>> successfully update the plugin (with the new image), but when Eclipse
>> restarts, the old image is still shown.
>> Config:
>> Eclipse 3.3.1
>> Windows XP
>> Java 1.6
>> Thanks
Derek
| Re: Replacing the splash image (via an update) [message #332713 is a reply to message #332703] |
Thu, 06 November 2008 10:33   |
Is it possible this bug is affecting Eclipse all the way back to 3.3.1? I
think it is plausible as this code was wrong for awhile.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=240915
(Note the bug I filed that exactly describes what you are seeing -
https://bugs.eclipse.org/bugs/show_bug.cgi?id=240731)
Mark.
On Thu, 06 Nov 2008 03:41:46 -0500, Derek <subs@_nospam_consertum.com>
wrote:
> Hi Andrew,
> installed.
>> the bmp.
>> to make sure you use splashPath or -showsplash to do a search.
>> extract the bitmap out of a jar.
>> -Andrew
>> Derek wrote:
>>> Hi,
>>> mechanism.
>>> Config:
>>> Eclipse 3.3.1
>>> Windows XP
>>> Java 1.6
>>> Thanks
| Re: Replacing the splash image (via an update) [message #332722 is a reply to message #332713] |
Thu, 06 November 2008 11:11   |
Yes Mark,
I do believe you are correct. That bug (240915) would have existed back
as far as 3.3.0.
One workaround for the problem would be to remove the -showsplash from
the eclipse.ini.
The order of precedence goes:
1) -showsplash <arg> : the native launcher finds the splash screen and
displays it before starting java. This overrides everything in the
config.ini
2) else, config.ini: osgi.splashLocation, osgi.splashPath. In Java, Main
finds the splash screen and displays it.
Due to the bug in the launcher, it is finding the wrong one. If you
remove the -showsplash, then Main will look instead and it does not
have that bug so should find the correct one. The difference between
the two cases is the launcher one shows earlier (the time it takes to
start the jvm).
-Andrew
> I think it is plausible as this code was wrong for awhile.
> Mark.
> wrote:
>> Hi Andrew,
>> then no splash is shown, even though there is a newer version of the
>> plugin installed.
>> Thanks,
>>> plugins folder disk for the given bundle and will choose the highest
>>> version.
>>> to the bmp.
>>> -Andrew
>>> Derek wrote:
>>>> Hi,
>>>> mechanism.
>>>> Eclipse restarts, the old image is still shown.
>>>> Config:
>>>> Eclipse 3.3.1
>>>> Windows XP
>>>> Java 1.6
>>>> Thanks
| Re: Replacing the splash image (via an update) [message #332727 is a reply to message #332713] |
Thu, 06 November 2008 12:10   |
Hi Mark,
Yup, that looks like my problem - I never thought to look in bugzilla (I
normally do!).
> Mark.
> wrote:
>> Hi Andrew,
>> plugin installed.
>> Thanks,
>>> version.
>>> to the bmp.
>>> -Andrew
>>> Derek wrote:
>>>> Hi,
>>>> mechanism.
>>>> Config:
>>>> Eclipse 3.3.1
>>>> Windows XP
>>>> Java 1.6
>>>> Thanks
Derek
| Re: Replacing the splash image (via an update) [message #332729 is a reply to message #332722] |
Thu, 06 November 2008 12:27  |
Andrew,
Removing -showsplash from eclipse.ini doesn't work (i.e doesn't find the
correct splash screen).
I have the osgi.splashPath in the config.ini and it references the
'base' branding plugin (no qualifier) - removing it shows no splash.
Any other suggestions?
> Yes Mark,
> as far as 3.3.0.
> the eclipse.ini.
> config.ini
> start the jvm).
> -Andrew
>> 3.3.1? I think it is plausible as this code was wrong for awhile.
>> Mark.
>> wrote:
>>> Hi Andrew,
>>> plugin installed.
>>> number of the branding plugin - but I can't find it... Any further
>>> ideas?
>>> Thanks,
>>>> version.
>>>> to the bmp.
>>>> is to make sure you use splashPath or -showsplash to do a search.
>>>> you craft p2 metadata to adjust the splash location directly.
>>>> only saved there after the location has been chosen and if we need
>>>> to extract the bitmap out of a jar.
>>>> -Andrew
>>>> Derek wrote:
>>>>> Hi,
>>>>> working fine. We are now wish to update the splash image via the
>>>>> update mechanism.
>>>>> Config:
>>>>> Eclipse 3.3.1
>>>>> Windows XP
>>>>> Java 1.6
>>>>> Thanks
Derek
Current Time: Tue Nov 18 18:37:50 EST 2025
Powered by FUDForum. Page generated in 0.03965 seconds
