Home » Eclipse Projects » Eclipse Platform » [p2] Works... the second time
[p2] Works... the second time [message #332693] Wed, 05 November 2008 06:53
I'm encountering some strange behaviour in p2 (using the 3.4.1 Modeling
distribution). For some update sites (but strangely enough not for all)
the following happens:
- I add an update site
- I select the check box next to it
- I press install
- The "Calculating requirements and dependencies" windows pops up
- It takes quite some time to fill the progress bar
- While the progress bar is being filled the check-boxes next to the
features of the update site are unticked (!!!)
- The Install window pops up with nothing in the list so I have to press
cancel
- I re-select the features under the update site, press install again
and then it works
(For example this happens with
http://download.eclipse.org/modeling/gmt/epsilon/updates/).
Anyone seen this before? Any idea what I may be doing wrong?
Dimtiris
Previous Topic:Override Open Action in Resource Navigator
Next Topic:[p2]Using links file in Eclipse 3.4
Current Time: Fri Jul 18 07:21:44 EDT 2025
Powered by FUDForum. Page generated in 0.06686 seconds
