Home » Eclipse Projects » Eclipse Platform » storageeditorinput and SAVE ???
storageeditorinput and SAVE ??? [message #332659] Tue, 04 November 2008 05:15 Go to next message
Hi all,
I have an object model that represents object in a database .
I have got an input stream / output stream to use during the load / save
operation .
The question is:
I did a MyEditorInput which extends a IStorageEditorInput .
Based on the extension file I open the eclipse default editor for that db
object (ie. Structured for xml file . texteditor for txt) .
No problem in opening the editor . but what shall I do to save it?
I don't want to implement the IPersistableElement what I need is press the
save button and be sure that the information will be passed to the output
stream ...
I have done previously this extending the (StructuredTextEditor) ... but
what shall I do to use the normal editors?
Kar
Re: storageeditorinput and SAVE ??? [message #332660 is a reply to message #332659] Tue, 04 November 2008 05:32 Go to previous messageGo to next message
Extend the editor's doSave(IProgressMonitor) and write to your
OutputStream there...?
Re: storageeditorinput and SAVE ??? [message #332665 is a reply to message #332660] Tue, 04 November 2008 06:27 Go to previous messageGo to next message
Hi Remy,
the problem is that I'm giving the user the possibility to open any possible
eclipse editor ...
or I do remove this option or I have to find a way to stick a listener on
the opened editor when this will get opened ..
any suggestion?
"Remy Chi Jian Suen" <remy.suen@gmail.com> wrote in message
news:gep89h$2p1$1@build.eclipse.org...
Re: storageeditorinput and SAVE ??? [message #332666 is a reply to message #332665] Tue, 04 November 2008 07:13 Go to previous messageGo to next message
Kar, there is no way you can know whether an editor supports saving back
to a given IEditorInput. If you check the API for the ISEI, it doesn't
even mention saving back to the underlying IStorage and suggests that a
new file resource be created for writing the contents.
"File-oriented editors should support this as a valid input type, and
display its content for viewing (but not allow modification). Within the
editor, the "save" and "save as" operations should create a new file
resource within the workspace."
http://help.eclipse.org/stable/nftopic/org.eclipse.platform. doc.isv/reference/api/org/eclipse/ui/IStorageEditorInput.htm l
Re: storageeditorinput and SAVE ??? [message #332673 is a reply to message #332666] Tue, 04 November 2008 10:31 Go to previous message
what about a file ... I mean I could export the memory information on a file
and create a filestoreeditorinput
would it be of any help ...
guess not I cannot see any link to save operation ... but I could probably
set some resource change listener ... but again this probably will work if
the file is inside eclipse and not only in the filesystem ...
news:gepe73$hgr$1@build.eclipse.org...
Previous Topic:How to get Linked Folders of a Project
Next Topic:Access restriction problem when using Java 6
Current Time: Sat Jul 26 18:07:40 EDT 2025
Powered by FUDForum. Page generated in 0.03384 seconds
