Home » Eclipse Projects » Eclipse Platform » cannot be cast to org.eclipse.ui.ide.FileStoreEditorInput
cannot be cast to org.eclipse.ui.ide.FileStoreEditorInput [message #332624] Sun, 02 November 2008 16:41 Go to next message
Hi there!
I have plugin written for 3.2. Now I try to run with 3.3, when I save my
editor context I get exception.
My EditorInput implements only IEditorInput. What is the problem?
java.lang.ClassCastException: ira.editors.EditorInput cannot be cast to
at ira.editors.Editor.doSave(Editor.java:122)
at org.eclipse.ui.internal.DefaultSaveable.doSave(DefaultSaveab le.java:54)
at org.eclipse.ui.Saveable.doSave(Saveable.java:212)
org.eclipse.ui.internal.SaveableHelper.doSaveModel(SaveableH elper.java:339)
at org.eclipse.ui.internal.SaveablesList$4.run(SaveablesList.ja va:610)
at org.eclipse.ui.internal.SaveableHelper$4.run(SaveableHelper. java:266)
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:458)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:366)
org.eclipse.jface.window.ApplicationWindow$1.run(Application Window.java:758)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
org.eclipse.jface.window.ApplicationWindow.run(ApplicationWi ndow.java:755)
at org.eclipse.ui.internal.WorkbenchWindow.run(WorkbenchWindow. java:2487)
org.eclipse.ui.internal.SaveableHelper.runProgressMonitorOpe ration(SaveableHelper.java:274)
at org.eclipse.ui.internal.SaveablesList.saveModels(SaveablesLi st.java:619)
org.eclipse.ui.internal.SaveablesList.promptForSaving(Saveab lesList.java:583)
org.eclipse.ui.internal.SaveablesList.promptForSavingIfNeces sary(SaveablesList.java:423)
org.eclipse.ui.internal.SaveablesList.preCloseParts(Saveable sList.java:383)
org.eclipse.ui.internal.WorkbenchPage.closeEditors(Workbench Page.java:1315)
org.eclipse.ui.internal.WorkbenchPage.closeEditor(WorkbenchP age.java:1402)
at org.eclipse.ui.internal.EditorPane.doHide(EditorPane.java:61 )
at org.eclipse.ui.internal.PartStack.close(PartStack.java:543)
at org.eclipse.ui.internal.EditorStack.close(EditorStack.java:2 06)
at org.eclipse.ui.internal.PartStack$1.close(PartStack.java:122 )
org.eclipse.ui.internal.presentations.util.TabbedStackPresen tation$1.handleEvent(TabbedStackPresentation.java:83)
org.eclipse.ui.internal.presentations.util.AbstractTabFolder .fireEvent(AbstractTabFolder.java:267)
org.eclipse.ui.internal.presentations.util.AbstractTabFolder .fireEvent(AbstractTabFolder.java:276)
org.eclipse.ui.internal.presentations.defaultpresentation.De faultTabFolder.access$1(DefaultTabFolder.java:1)
org.eclipse.ui.internal.presentations.defaultpresentation.De faultTabFolder$1.closeButtonPressed(DefaultTabFolder.java:70 )
org.eclipse.ui.internal.presentations.PaneFolder.notifyClose Listeners(PaneFolder.java:626)
org.eclipse.ui.internal.presentations.PaneFolder$3.close(Pan eFolder.java:206)
at org.eclipse.swt.custom.CTabFolder.onMouse(CTabFolder.java:21 71)
at org.eclipse.swt.custom.CTabFolder$1.handleEvent(CTabFolder.j ava:324)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3823)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3422)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2382)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2346)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 98)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:493)
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:488)
at myrcp.Application.run(Application.java:195)
org.eclipse.equinox.internal.app.EclipseAppContainer.callMet hodWithException(EclipseAppContainer.java:574)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:195)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:386)
at org.eclipse.equinox.launcher.Main.main(Main.java:1212)
Re: cannot be cast to org.eclipse.ui.ide.FileStoreEditorInput [message #332626 is a reply to message #332624] Sun, 02 November 2008 19:12 Go to previous messageGo to next message
The problem is:
I created both MyEditor and MyEditorInput classes. When I create new
MyEditor I pass instance of my MyEditorInput.But when I open file, workbench
creates MyEditor but call init() with FileStoreEditorInput as parameter.So,
when I call getEditorInput() I may have my MyEditoInput or
FileStoreEditorInput. It causes the problem, because I try to cast them.I
can check if I get MyEditoInput or FileStoreEditorInput, but it doesn't look
nice. So, what is right way to handle this situation?
Thank you,
Andrey
Re: cannot be cast to org.eclipse.ui.ide.FileStoreEditorInput [message #332642 is a reply to message #332626] Mon, 03 November 2008 07:59 Go to previous messageGo to next message
Do you need to be able to open an IFile? Or if you are associated with
a file extension and you need to operate in the workspace, why write
MyEditorInput?
PW
Paul Webster
Re: cannot be cast to org.eclipse.ui.ide.FileStoreEditorInput [message #332644 is a reply to message #332626] Mon, 03 November 2008 08:18 Go to previous messageGo to next message
When you open a file outside of the workspace (like File > Open...),
Eclipse will use a FileStoreEditorInput (as you discovered). As far as I
know, there is no way of knowing that MyEditorInput is supposed to match
with MyEditor so I'm not even sure how your code originally worked in
3.2. What are you adding to MyEditorInput that can't be satisfied by the
framework's original IEditorInput implementations?
Re: cannot be cast to org.eclipse.ui.ide.FileStoreEditorInput [message #332650 is a reply to message #332642] Mon, 03 November 2008 12:29 Go to previous messageGo to next message
Originally posted by: andrey.int.com
I have simple RCP application with several Views and Editors. I have to open
data file, modify it and save.
I don't use workspace at all.My understanding is I have to implement
IEditorInput interface.
"Paul Webster" <pwebster@ca.ibm.com> wrote in message
news:gemt12$i01$2@build.eclipse.org...
> Do you need to be able to open an IFile? Or if you are associated with a
> MyEditorInput?
> PW
> Paul Webster
Re: cannot be cast to org.eclipse.ui.ide.FileStoreEditorInput [message #332656 is a reply to message #332644] Mon, 03 November 2008 23:21 Go to previous messageGo to next message
I need simple thing- read and write file. IEditorInput doesn't allow to do
it. So, I implemented my own EditorInput
which keeps path to the file. It was fine in 3.1 (not 3.2, I was mistaken).
But now I have a problem.
What is the right way to work with files wich are not in workplace?
Thank you,
Andrey
Re: cannot be cast to org.eclipse.ui.ide.FileStoreEditorInput [message #332658 is a reply to message #332656] Tue, 04 November 2008 02:58 Go to previous messageGo to next message
File R/W should be handled by FileStoreEditorInput. I would suggest you
open editors using that instead of your own MyEditorInput. To reiterate,
what is special about your IEditorInput implementation that can't be
satisfied? If you need to open non-workspace resources, you should use
the FSEI class in my opinion. Please provide more context to your
application's setup.
Re: cannot be cast to org.eclipse.ui.ide.FileStoreEditorInput [message #332667 is a reply to message #332658] Tue, 04 November 2008 08:17 Go to previous messageGo to next message
> satisfied? If you need to open non-workspace resources, you should use the
Actually, nothing. But how to create FSEI? It requires IFileStore in
constructor. How to pass local file to FSEI?
Thnak tyou,
Andrey
Re: cannot be cast to org.eclipse.ui.ide.FileStoreEditorInput [message #332668 is a reply to message #332667] Tue, 04 November 2008 08:43 Go to previous messageGo to next message
http://wiki.eclipse.org/EFS
http://help.eclipse.org/stable/nftopic/org.eclipse.platform. doc.isv/reference/api/org/eclipse/core/filesystem/package-su mmary.html
Use EFS.getLocalFileSystem(). I think you can figure it out from there.
Re: cannot be cast to org.eclipse.ui.ide.FileStoreEditorInput [message #332684 is a reply to message #332668] Tue, 04 November 2008 21:53 Go to previous messageGo to next message
Thanks for links. Actually there is a complication here.
The reason why I need my own EditorInput is:
When I create new editor, there is no any file in file system. So, I create
new Model (which provides content I will edit) and pass it to editor using
my EditorInput. It looks like:
EditorInput ei=new EditorInput( new Model());
window.getActivePage().openEditor(ei, Editor.ID);
So I need special EditorInput, which keeps my model. I don't see how I can
use standard EditorInput.What do I miss?
Thank you,
Andrey
Re: cannot be cast to org.eclipse.ui.ide.FileStoreEditorInput [message #332711 is a reply to message #332684] Thu, 06 November 2008 09:59 Go to previous messageGo to next message
Just so you know, it's extremely not recommended that you put model
objects in your IEditorInput itself. Read the javadoc for IEditorInput.
Think java.io.File, it's simply a key that would allow your editor to
load the content you need.
PW
Paul Webster
Re: cannot be cast to org.eclipse.ui.ide.FileStoreEditorInput [message #332868 is a reply to message #332711] Tue, 11 November 2008 12:37 Go to previous messageGo to next message
I agree. Having model in IEditorInput is not good idea. But what should I do
when I create new editor?
There is no any File at this moment. I don't see how I can tell editor to
create new model. I tried to pass null as IEditorInput. It doesn't work
null is not allowed.
Thank you,
Andrey
news:gev161$23q$1@build.eclipse.org...
> Think java.io.File, it's simply a key that would allow your editor to load
> PW
> Paul Webster
Re: cannot be cast to org.eclipse.ui.ide.FileStoreEditorInput [message #332878 is a reply to message #332868] Wed, 12 November 2008 01:48 Go to previous messageGo to next message
I tried opening an editor on a non-existing file. It works fine
IFileStore store = EFS.getLocalFileSystem().getStore(new
Path("C:\\NoSuchFile.txt"));
IDE.openEditor(activePage, new FileStoreEditorInput(store),
"org.eclipse.ui.DefaultTextEditor");
So probably the issue would be in your editor. Probably in the place
where you create your model from the file (setInput?), check whether the
file exists and if not, create an empty model.
- Prakash
http://blog.eclipse-tips.com
Re: cannot be cast to org.eclipse.ui.ide.FileStoreEditorInput [message #332885 is a reply to message #332878] Wed, 12 November 2008 08:26 Go to previous message
Create a new file and open non existing file are different things. If you
open file which doesn't exixt (someone deleted it) this is an exceptional
situation and you have to notify user. Creating a new file is regular
procedure, you have to create new editor, that's it. What I found in eclipse
sources (Java editor probably) is creating special implementation of
IEditorInput which is not connected to any file. Is it a supposed way to
create new editor?
Thank you,
Andrey
"Prakash G.R." <grprakash@gmail.com> wrote in message
news:gfdu71$e2d$1@build.eclipse.org...
> - Prakash
Previous Topic:view and multiple viewers
Next Topic:How to list features of local update site?
Current Time: Tue Jul 22 02:46:03 EDT 2025
Powered by FUDForum. Page generated in 0.21850 seconds
