Home » Archived » Jubula » login splashScreen isn't detected when launching E4 application AUT
login splashScreen isn't detected when launching E4 application AUT [message #1771358] Thu, 24 August 2017 06:48 Go to next message
Hello all,
When I start my AUT (RCP E4application) , Jubula don't detect the login spalsh Screen ,but after authentication the AUT is started and the next page is detected
my code to start my application is like this :
public class TestE4Application extends E4Application {
public Object start(IApplicationContext applicationContext) throws Exception {
LoginController splashController = new LoginController());
splashController.openSplash();
return super.start(applicationContext);
I would know in each step of code the jubula detcted the view and start succefully
Thank you for your help
Re: login splashScreen isn't detected when launching E4 application AUT [message #1771638 is a reply to message #1771358] Tue, 29 August 2017 01:25 Go to previous messageGo to next message
Hi there,
for Jubula, the AUT isn't started until the workbench is loaded - and that hasn't happened when the splash screen is showing. This is normal behaviour.
If you need to interact with the splash screen (e.g. by entering a workspace), then you should configure this as a part of the AUT configuration (e.g. by using the -data parameter in the AUT arguments field).
Alex
Re: login splashScreen isn't detected when launching E4 application AUT [message #1771694 is a reply to message #1771638] Tue, 29 August 2017 10:41 Go to previous messageGo to next message
Hello Alexandra,
Thank you for your help,
my SplashScreen contains login and password field
by using -data can I pass login and password data in the AUT arguments ? or there is an other way ?
Thank you
Re: login splashScreen isn't detected when launching E4 application AUT [message #1771753 is a reply to message #1771694] Wed, 30 August 2017 03:53 Go to previous message
Hi Tarik,
As far as I know you can pass the username and password via the AUT arguments. I assume you could also pass the data in the application start up file or in various other ways, but I'm afraid I can't tell you how.
Alex
Previous Topic:Replace text in a numberfield
Next Topic:Jubula 8.5 API Converter: Error while converting a project
Current Time: Tue Jul 15 02:27:50 EDT 2025
Powered by FUDForum. Page generated in 0.07852 seconds
