How to generate plugin's javadoc from ant ? [message #332611] |
Fri, 31 October 2008 05:14 |
Hey,
I was wondering how to generate plugin's javadoc from an ant build file,
I generated this ant build file from the IDE using export=>javadoc but I
had a few issues :
* the produced file contains a classpath pointing to dependent
projects bin (ie. output) directory and the pde build task :
pde.exportPlugins doesn't create .class files in the bin (ie. output)
directories
I fix this issue by using the eclipse.incrementalbuild task
* the produced file contains a classpath with the full name of the
dependent jars (with version number). If anyone of this plugins version
changes the build file will no more work.
How can I find my plugin's classpath (ie. regenerating it) from an ant
build file to solve this issue ?
(I tried the eclipse.buildscript task, but I don't really understand
what should be generated by this task)
Guillaume.
FUDForum. Page generated in 0.20233 seconds
