Home » Eclipse Projects » Eclipse Platform » How to customize variable view
How to customize variable view [message #332508] Thu, 23 October 2008 19:08 Go to next message
I am trying to find a way to customize what columns are shown in variable
view by default.
For example, when I open variable view, I want "variable", "value",
"actual type" be shown by default.
Thanks for your suggestion.
Rong
Re: How to customize variable view [message #332530 is a reply to message #332508] Mon, 27 October 2008 07:45 Go to previous messageGo to next message
> variable view by default.
Are your column settings not getting persisted across workbench shutdown
when you enable 'Actual Type' as a column?
Remy
Re: How to customize variable view [message #332564 is a reply to message #332530] Tue, 28 October 2008 20:34 Go to previous messageGo to next message
That would work fine. I would want to programmatic have "Actual Type"
turned on instead of having user to add that column manually. Is that
possible?
Re: How to customize variable view [message #332567 is a reply to message #332564] Wed, 29 October 2008 02:21 Go to previous message
> possible?
Eh, I don't see why not unless it's hard coded. You'd have to check the
code of 'Variables' view and friends to see which preference it's
loading I s'pose.
Previous Topic:Information on self hosting.
Next Topic:My plugin is not running by adding in from URL in MacOS
Current Time: Fri Jul 18 17:02:41 EDT 2025
Powered by FUDForum. Page generated in 0.07194 seconds
