Home » Eclipse Projects » Eclipse Platform » Menu URI to make contributions to Context menu on Coolbar.
Menu URI to make contributions to Context menu on Coolbar. [message #332502] Thu, 23 October 2008 14:04 Go to next message
Is there an RCP defined popup URI that allows menuContributions to the
coolbar popup?
Re: Menu URI to make contributions to Context menu on Coolbar. [message #332520 is a reply to message #332502] Fri, 24 October 2008 15:24 Go to previous messageGo to next message
> coolbar popup?
Those system menus don't have contribution URIs at the moment. That
would have to be an enhancement request (and targetted for 3.5)
PW
Paul Webster
Re: Menu URI to make contributions to Context menu on Coolbar. [message #332561 is a reply to message #332520] Tue, 28 October 2008 16:19 Go to previous messageGo to next message
Where is it defined in the IDE... i've been trying to find the URI
definition somewhere in the ide jars.
This is what i'm doing
IMenuService menuService =
(IMenuService)PlatformUI.getWorkbench().getService( IMenuService.class );
MenuManager menuMgr = new MenuManager( "ToolbarPopup",
"popup:my.popup.id" );
menuMgr.add( new Separator(
IWorkbenchActionConstants.MB_ADDITIONS ) );
menuService.populateContributionManager( menuMgr,
Menu m = menuMgr.createContextMenu( coolbar );
coolbar.setMenu( m );
In my plugin.xmls i just make contributions the the
"popup:my.popup.id?after=additions"
This works... i was just trying to figure out the proper way since i'm
seeing some funny business when toolbars show/hide themselves.
>> coolbar popup?
> PW
Re: Menu URI to make contributions to Context menu on Coolbar. [message #332573 is a reply to message #332561] Wed, 29 October 2008 09:25 Go to previous messageGo to next message
Amongst other things, you are overriding the workbench provided popup.
That doesn't sound like a good idea to me, and what about a Menu that
already exists there (we shouldn't leak it).
PW
Paul Webster
Re: Menu URI to make contributions to Context menu on Coolbar. [message #332575 is a reply to message #332573] Wed, 29 October 2008 10:20 Go to previous messageGo to next message
Paul,
Thanks a ton for the input!
I need to make contributions to the popup on the coolbar.
I understand that I may be doing it incorrectly but how do I do it
properly?
I'm sure this is straight forward... every application that uses the RCP
would want this??
kjm
> PW
Re: Menu URI to make contributions to Context menu on Coolbar. [message #332614 is a reply to message #332575] Fri, 31 October 2008 10:59 Go to previous messageGo to next message
> Paul,
> properly?
You can't. There's no API to contribute to that menus (controlled by
the internal window, I believe. Same thing with the editor or view
stack tab menus. They're owned by the presentation and so are not
currently extensible.
That doesn't mean that they cannot be extended, but AFAIK there's no API
to do it.
PW
Paul Webster
Re: Menu URI to make contributions to Context menu on Coolbar. [message #333269 is a reply to message #332614] Tue, 02 December 2008 16:11 Go to previous messageGo to next message
Paul, I've done some research and found where the IDE plugins define the
coolbar popup:
org.eclipse.ui.internal.ide.WorkbenchActionBuilder:
protected void fillCoolBar(ICoolBarManager coolBar)
IActionBarConfigurer2 actionBarConfigurer = (IActionBarConfigurer2)
getActionBarConfigurer();
{ // Set up the context Menu
coolbarPopupMenuManager = new MenuManager();
coolbarPopupMenuManager.add(new
ActionContributionItem(lockToolBarAction));
ActionContributionItem(editActionSetAction));
coolBar.setContextMenuManager(coolbarPopupMenuManager);
IMenuService menuService = (IMenuService)
window.getService(IMenuService.class);
menuService.populateContributionManager( coolbarPopupMenuManager,
"popup:windowCoolbarContextMenu");
I've tried this and it seems to work great if all toolbar items were
added programatically but as soon as a declared toolbar item shows up
the active toolbar doesn't seem to fwd the 'getmenu' call up to the
Coolbar. It seems to ALWAYS work when you right click on any toolbars
handle ( vertical dots ).
Is this behavior you expect or is there some code that i'm missing to
make sure that the popup menu shows on all toolbars in the coolbar?
Thanks in advance.
kjm
>> Paul,
>> properly?
> to do it.
> PW
Re: Menu URI to make contributions to Context menu on Coolbar. [message #333298 is a reply to message #333269] Wed, 03 December 2008 10:37 Go to previous messageGo to next message
> coolbarPopupMenuManager, "popup:windowCoolbarContextMenu");
Wow, that looks odd :-)
This sounds like a bug (although the contributed commands and created
actions should work the same way). Please open a bug with a
reproducible test case at
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Platform &component=UI&short_desc=[Contributions]
PW
Paul Webster
Re: Menu URI to make contributions to Context menu on Coolbar. [message #333355 is a reply to message #333298] Thu, 04 December 2008 15:32 Go to previous message
Bug 257612 [Contributions] Problems with Context Menu on Coolbar.
> PW
Previous Topic:Does the Common Navigator Framework (CNF) support Capabilities?
Next Topic:Change to shift click function
Current Time: Tue Jul 22 21:19:38 EDT 2025
Powered by FUDForum. Page generated in 0.05666 seconds
