Home » Eclipse Projects » Eclipse Platform » Problem integrating equinox transforms (xslt)
Problem integrating equinox transforms (xslt) [message #332494] Thu, 23 October 2008 03:50 Go to next message
Hi everyone,
I am currently trying to integrate equinox transforms as described on
http://wiki.eclipse.org/Equinox_Transforms. For my sample application this
works perfectly but not when I try to integrate it into my real
application.
What I'm trying to do:
I'm trying to disable menu contributions from org.eclipse.ui.ide. The
"Working sets"-item from the "Window" menu would be an example. Therefore
I'm trying to integrate equinox transforms as described in the wiki.
What I've done so far:
1. I created a new Plugin containing an Activator including the following
code
Properties properties = new Properties();
properties.put("equinox.transformerType", "xslt");
registration = context.registerService(URL.class.getName(),
context.getBundle().getEntry("/transform.csv"), properties);
2. I created the transform.csv an a xsl-stylesheet
3. I added the new plugin to my feature
4. I created a config.ini file containing the following
#Product Runtime Configuration File
osgi.splashPath=platform:/base/plugins/de.tecis.excalibur.e2
eclipse.product=de.tecis.excalibur.e2.product
osgi.bundles=org.eclipse.equinox.transforms.xslt@1:start,de.tecis.excalibur.equinox.transforms@1:start,org.eclipse.equinox.common@2:start,org.eclipse.update.configurator@3:start,org.eclipse.core.runtime@start
osgi.bundles.defaultStartLevel=4
osgi.framework.extensions=org.eclipse.equinox.transforms.hoo k
The plugin de.tecis.excalibur.equinox.transforms is the newly created
plugin.
The equinox transforms service seems to start correctly when I comment the
following line from config.ini
osgi.framework.extensions=org.eclipse.equinox.transforms.hoo k because the
osgi console gives me the following
0 ACTIVE org.eclipse.osgi_3.3.2.R33x_v20080105
Fragments=68
1 ACTIVE de.tecis.excalibur.equinox.transforms_1.4.0.rc3
68 RESOLVED org.eclipse.equinox.transforms.hook_1.0.0.v20080610
Master=0
When I uncomment the above line I get the following error.
org.osgi.framework.BundleException: The activator
de.tecis.excalibur.e2.E2Plugin for bundle de.tecis.excalibur.e2 is invalid
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:141)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:970)
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:346)
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:260)
org.eclipse.osgi.framework.util.SecureAction.start(SecureAct ion.java:400)
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:111)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:417)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:189)
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:340)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:408)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:369)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:357)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:83)
org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:289)
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:227)
org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1269)
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:160)
org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:788)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:165)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
at org.eclipse.equinox.launcher.Main.main(Main.java:1148)
Caused by: java.lang.NullPointerException
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.cre ateProtectionDomain(DefaultClassLoader.java:226)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.cre ateClassPathEntry(DefaultClassLoader.java:157)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.createC lassPathEntry(ClasspathManager.java:252)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.getClas spath(ClasspathManager.java:219)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.addClas sPathEntry(ClasspathManager.java:182)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findCla ssPathEntry(ClasspathManager.java:160)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.buildCl asspath(ClasspathManager.java:138)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.initial ize(ClasspathManager.java:72)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.ini tialize(DefaultClassLoader.java:177)
org.eclipse.osgi.framework.internal.core.BundleLoader.create BCL(BundleLoader.java:714)
org.eclipse.osgi.framework.internal.core.BundleLoader.create BCLPrevileged(BundleLoader.java:689)
org.eclipse.osgi.framework.internal.core.BundleLoader.create ClassLoader(BundleLoader.java:318)
org.eclipse.osgi.framework.internal.core.SingleSourcePackage .loadClass(SingleSourcePackage.java:37)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:405)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
at java.lang.Class.getDeclaredConstructors0(Native Method)
at java.lang.Class.privateGetDeclaredConstructors(Unknown Source)
at java.lang.Class.getConstructor0(Unknown Source)
at java.lang.Class.newInstance0(Unknown Source)
at java.lang.Class.newInstance(Unknown Source)
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:136)
... 33 more
Root exception:
Somehow suddly he doesn't seem to find the activator of my application
bundle anymore.
I guess there is a problem with the classloader but I cannot find where
the problem is. Maybe someone could point me into the right direction and
give me a hint of what I might be doing wrong.
Thanks in advance for any help.
Ch. Hager
Re: Problem integrating equinox transforms (xslt) [message #332498 is a reply to message #332494] Thu, 23 October 2008 09:33 Go to previous message
Ch. Hager wrote:
> Hi everyone,
> this works perfectly but not when I try to integrate it into my real
> application.
> Therefore I'm trying to integrate equinox transforms as described in the
> wiki.
> following code
> plugin.
> the following line from config.ini
> the osgi console gives me the following
> Fragments=68
> Master=0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.lang.ClassLoader.loadClass(Unknown Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> .. 33 more
> Root exception:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> bundle anymore.
> and give me a hint of what I might be doing wrong.
> Ch. Hager
What does the config.ini look like when you launch your test app from
eclipse (you can usually find it if you look at the command line eclipse
generates in the debug view).
I've redirected to equinox as they're in a better position to answer this.
PW
Paul Webster
Previous Topic:Disable rename/move popup menu
Next Topic:Marker Annotations disapperaring in vertical toolbar
Current Time: Wed Jul 16 19:38:57 EDT 2025
Powered by FUDForum. Page generated in 0.03730 seconds
