Home » Eclipse Projects » Eclipse Platform » [swt][cocoa] Cannot run an Eclipse application with the SWT Cocoa port
[swt][cocoa] Cannot run an Eclipse application with the SWT Cocoa port [message #332420] Tue, 21 October 2008 06:51 Go to next message
Originally posted by: atoulme.intalio.com
I'd like to test the current state of the SWT Cocoa port.
Here is what I did:
I checked out the sources of org.eclipse.swt and org.eclipse.swt.coca.macosx
I renamed the cocoa classpath file to be the .classpath file.
I built those plugins.
Then I tried to start my eclipse instance, and I had this exception:
!ENTRY org.eclipse.osgi 4 0 2008-10-21 12:23:01.185
!MESSAGE Application error
!STACK 1
java.lang.UnsatisfiedLinkError: no swt-cocoa-3513 or swt-cocoa in
swt.library.path, java.library.path or the jar file
at org.eclipse.swt.internal.Library.loadLibrary(Library.java:23 5)
at org.eclipse.swt.internal.Library.loadLibrary(Library.java:15 3)
at org.eclipse.swt.internal.C.<clinit>(C.java:21)
at org.eclipse.swt.internal.cocoa.id.objc_getClass(id.java:35)
at org.eclipse.swt.internal.cocoa.NSObject.alloc(NSObject.java: 28)
at org.eclipse.swt.graphics.Device.<init>(Device.java:116)
at org.eclipse.swt.widgets.Display.<init>(Display.java:542)
at org.eclipse.swt.widgets.Display.<init>(Display.java:533)
at org.eclipse.ui.internal.Workbench.createDisplay(Workbench.ja va:525)
at org.eclipse.ui.PlatformUI.createDisplay(PlatformUI.java:161)
org.eclipse.ui.internal.ide.application.IDEApplication.creat eDisplay(IDEApplication.java:143)
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:88)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:386)
at org.eclipse.equinox.launcher.Main.main(Main.java:1212)
What can I do about this ? Is there an error on my end ?
Antoine
Re: [swt][cocoa] Cannot run an Eclipse application with the SWT Cocoa port [message #332425 is a reply to message #332420] Tue, 21 October 2008 10:14 Go to previous messageGo to next message
Sorry, should have posted to the swt newsgroup.
Antoine
Antoine Toulme wrote:
> Here is what I did:
> !STACK 1
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Antoine
Re: [swt][cocoa] Cannot run an Eclipse application with the SWT Cocoa port [message #332427 is a reply to message #332425] Tue, 21 October 2008 11:01 Go to previous messageGo to next message
Hi Antoine,
You may have checked out from HEAD while we were in the middle of an
integration build yesterday evening. Do you see the libraries with the
correct version (3513) in the org.eclipse.swt.coca.macosx fragment?
I just checked out from HEAD this morning and I was able to launch my
examples. Can you update and try it again?
Duong
Re: [swt][cocoa] Cannot run an Eclipse application with the SWT Cocoa port [message #332431 is a reply to message #332427] Tue, 21 October 2008 12:21 Go to previous messageGo to next message
I updated, rebuilt, restarted, same error.
The contents of the cocoa fragment :
about_files
META-INF
..project
about.html
build.properties
build.xml
fragment.properties
libswt-awt-cocoa-3513.jnilib
libswt-cocoa-3513.jnilib
libswt-pi-cocoa-3513.jnilib
libswt-xulrunner-cocoa-3513.jnilib
I'm pretty sure this has more to do with running the Cocoa port in an
Eclipse instance.
Can you run an Eclipse instance with the cocoa port, or just your samples ?
Antoine
Duong Nguyen wrote:
> Hi Antoine,
> Duong
Re: [swt][cocoa] Cannot run an Eclipse application with the SWT Cocoa port [message #332439 is a reply to message #332431] Tue, 21 October 2008 13:54 Go to previous messageGo to next message
> Eclipse instance.
I'm running with a recent cocoa build and I can run another Eclipse
instance (self host). What version of Eclipse are you using? Is your host
Eclipse environment carbon? If yes, you'll need to change the target
platform environment variable to cocoa.
STEPS:
- open the Preferences page - select Preferences from the Window menu
- select Plug-in Development->Target Platform
- select Environment tab
- if the Window System isn't cocoa, change it to cocoa
- press Apply and close the preferences dialog
As an alternative, you can download the latest cocoa build of Eclipse and
run it.
Re: [swt][cocoa] Cannot run an Eclipse application with the SWT Cocoa port [message #332447 is a reply to message #332439] Tue, 21 October 2008 15:24 Go to previous message
OK, it worked! Awesome, thanks!
Antoine
>> Eclipse instance.
>> samples ?
> host Eclipse environment carbon? If yes, you'll need to change the
> target platform environment variable to cocoa.
> STEPS:
> and run it.
Previous Topic:Is there a listener for project references changed event
Next Topic:How to remote debug?
Current Time: Fri Jul 18 20:11:07 EDT 2025
Powered by FUDForum. Page generated in 1.54753 seconds
