Home » Eclipse Projects » Eclipse Platform » How to create a "document literal wrapped" WSDL ?
How to create a "document literal wrapped" WSDL ? [message #332385] Mon, 20 October 2008 16:07 Go to next message
Originally posted by: garywill.usca.edu
When I create a new WSDL I am asked on the options page which
"SOAP Binding option" I would like to use:
- document literal
- rpc literal
- rpc encoded
I miss an entry for:
- document literal wrapped
This style is described e.g. on page:
http://www.ibm.com/developerworks/webservices/library/ws-whi chwsdl/
How can I get this WSDL skeleton?
Gary
Re: How to create a "document literal wrapped" WSDL ? [message #332390 is a reply to message #332385] Mon, 20 October 2008 16:34 Go to previous messageGo to next message
Gary,
I guess you're using the Web Tools project for this and should ask on
the WTP newsgroup, which I've added to the "to" list of the reply.
> - document literal
> - rpc literal
> - rpc encoded
> Gary
Re: How to create a "document literal wrapped" WSDL ? [message #332395 is a reply to message #332390] Mon, 20 October 2008 17:02 Go to previous message
Hi Gary,
From the article:
"This wrapped style originates from Microsoft®. There is no specification
that defines this style; so while this style is a good thing,
unfortunately, the only choice right now, in order to interoperate with
Microsoft's and other's implementations, is to make educated guesses as to
how it works based on the output of the Microsoft WSDL generator. This
pattern has been around for awhile, and the industry has done a good job
of understanding it, but while the pattern is fairly obvious in this
example, there are corner cases in which the proper thing to do is not
particularly clear. Our best hope is that an independent group like the
WS-I organization will help stabilize and standardize this in the future."
Given that there is no standard and that this is a MS specific pattern I
think it is out of scope of WTP to provide support for this binding. Of
course I'm no longer part of WTP leadership so perhaps someone like Kathy
Chan or Valentin Baciu would have a more official answer.
That said, if you want to use the binding you don't need to rely on the
wizard. Generate the WSDL, open the WSDL file, change to the source tab,
and make the required changes as outlined in the article.
Lawrence Mandel
Co-author Eclipse Web Tools Platform: Developing Java Web Applications
http://www.eclipsewtp.org
>Gary,
>> - document literal
>> - rpc literal
>> - rpc encoded
>> Gary
Previous Topic:Where is TextActionHandler?
Next Topic:Debugger problems on 2nd run
Current Time: Mon Jul 21 21:24:49 EDT 2025
Powered by FUDForum. Page generated in 0.07710 seconds
