Home » Eclipse Projects » Eclipse Platform » commands contribution ...
commands contribution ... [message #332299] Fri, 17 October 2008 10:30 Go to next message
Hi all,
I have a question on commands added to a menu via CompoundContributionItem
I do use this way to display each time a different list of command/action
depending on some status of my plugin to a view context menu.
The question is:
protected IContributionItem[] getContributionItems()
let me return a list of CommandContributionItem
for (int i = 0; i < size; i++)
listCommands[i] = new
CommandContributionItem(PlatformUI.getWorkbench().getActiveW orkbenchWindow(),
scriptsName[i], "my.project.myCommand",
Collections.emptyMap(), null, null, null, scriptsName [i] , null,
null, SWT.NONE);
I guess there is a way to pass parameter to this command that can be used
later by the handler ... but how to do this?
this could be probably the map ... but how to use it? trying to put some
value to the hash map gives an error during the creation command.
I'm using eclise 3.3.2 (I have seen that in 3.4 things are lil different)
Kar
Re: commands contribution ... [message #332311 is a reply to message #332299] Fri, 17 October 2008 14:25 Go to previous message
If you want to pass a parameter in the map it needs to be in the command
definition as well (the commandParameter element).
PW
Paul Webster
Previous Topic:Building Eclipse 3.4.1 From Source Fails
Next Topic:Can a builder relate to another builder?
Current Time: Mon Jul 21 22:27:31 EDT 2025
Powered by FUDForum. Page generated in 0.09058 seconds
