Home » Eclipse Projects » Eclipse Platform » ViewPart.createPartControl( )
ViewPart.createPartControl( ) [message #332250] Tue, 14 October 2008 09:57 Go to next message
Hi all,
Is there any way to get my View's "Size" inside the createPartControl()
method ?
In fact I want to access this information because the view display
information at a different granularity level depending on the available
space ...
After deep step inside Eclipse's internal code it seems to be impossible :
// the part should never be visible by default. It will be made visible
// by activation. This allows us to have views appear in tabs without
// becoming active by default.
control.setVisible(false);
My view is filled through the createPartControl( ) method and is made
visible after leaving this method only if the view has been asked for
activation.
Can anybody confirm ?
Thanks in advance
Manu
Re: ViewPart.createPartControl( ) [message #332251 is a reply to message #332250] Tue, 14 October 2008 10:07 Go to previous message
You would have to add a resize listener to your view, then you can
update your controls when its size changes ... no? that would work for
the case where the initial size is 0,0 (when creatPartControl(*) is
called but the client area has not been layed out yet).
PW
Paul Webster
Previous Topic:Can't use Update manager in 3.3.2
Next Topic:Update Wizard
Current Time: Tue Nov 25 18:21:51 EST 2025
Powered by FUDForum. Page generated in 0.03762 seconds
