Eclipse update fails [message #332239] |
Tue, 14 October 2008 04:01  |
Since a few days back (don't know exactly how long) I cannot update my
Eclipse any longer. It doesn't matter if I try to update a plugin manually
using the GUI or if it is an automatic upate, the errors are the same
Cannot complete the request. See the details.
Cannot find a solution where both Match[requiredCapability:
org.eclipse.equinox.p2.iu/org.eclipse.swt/[3.4.1.v3449c,3.4. 1.v3449c]] and
org.eclipse.equinox.p2.iu/org.eclipse.swt/[3.4.0.v3448f,3.4. 0.v3448f]] can
be satisfied.
org.eclipse.equinox.p2.iu/org.eclipse.rcp.feature.jar/[3.4.1 00.r341_v20080814-989JESIEdAciFYfkZZsBfSwQ2341,3.4.100.r341_ v20080814-989JESIEdAciFYfkZZsBfSwQ2341]]
and Match[requiredCapability:
org.eclipse.equinox.p2.iu/org.eclipse.rcp.feature.jar/[3.4.0 .v20080324a-989JERhEk-jWnd5IY8K5tjxB,3.4.0.v20080324a-989JER hEk-jWnd5IY8K5tjxB]]
can be satisfied.
There's a lot more of those errors. I've searched the newsgroups but
there's no mention of this, Does anyone have a clue to what the problem is?
Re: Eclipse update fails [message #332242 is a reply to message #332239] |
Tue, 14 October 2008 05:33  |
mikael.springer@bredband.net (Mikael Springer) writes:
> manually using the GUI or if it is an automatic upate, the errors are
> the same
There is what looks like a report of the same problem in
eclipse.newcomer.
Are you using a web proxy and does it have a cache? I have found that
to cause a lot of trouble with update.
I have just submitted a bug report:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=250740 for the cache
problem so it that turns out to be the problem here you can add a
comment.
Owen Rees; speaking personally, and not on behalf of HP.
Hewlett-Packard Limited. Registered No: 690597 England
Registered Office: Cain Road, Bracknell, Berks RG12 1HN
FUDForum. Page generated in 0.03858 seconds
