Home » Eclipse Projects » Eclipse Platform » Content Assist shortcut - am I losing my mind?
Content Assist shortcut - am I losing my mind? [message #332224] Mon, 13 October 2008 07:22 Go to next message
I've created a custom editor, and an IContentAssistProcessor that's been
set for all the appropriate partition types. Auto-activation works fine,
but Ctrl+Space doesn't trigger code completion.
Is there something I need to do to configure this to work? If not, what
could I have done to *stop* it from working?
Adrian
Re: Content Assist shortcut - am I losing my mind? [message #332225 is a reply to message #332224] Mon, 13 October 2008 08:11 Go to previous messageGo to next message
> been set for all the appropriate partition types. Auto-activation
> works fine, but Ctrl+Space doesn't trigger code completion.
> what could I have done to *stop* it from working?
Yes you need to register the action for the command. Look at
org.eclipse.ui.texteditor.ContentAssistAction and how it is setup by the
Java editor for example.
Dani
> Adrian
Re: Content Assist shortcut - am I losing my mind? [message #332226 is a reply to message #332225] Mon, 13 October 2008 08:16 Go to previous messageGo to next message
Also, this FAQ may help.
http://wiki.eclipse.org/FAQ_How_do_I_add_Content_Assist_to_m y_editor%3F
Dani, are there any plans to create a command/handler/something that
won't require people to pass in their own ResourceBundles? I think this
will help reduce duplicated code and make localization easier.
Rem
Re: Content Assist shortcut - am I losing my mind? [message #332227 is a reply to message #332226] Mon, 13 October 2008 08:18 Go to previous messageGo to next message
>> the Java editor for example.
No plans but if there's a bug I might consider ;-)
Dani
> I think this will help reduce duplicated code and make localization
> easier.
> Rem
Re: Content Assist shortcut - am I losing my mind? [message #332229 is a reply to message #332227] Mon, 13 October 2008 08:23 Go to previous messageGo to next message
See: https://bugs.eclipse.org/bugs/show_bug.cgi?id=138370
Dani
> Dani
>> easier.
>> Regards,
>> Rem
Re: Content Assist shortcut - am I losing my mind? [message #332231 is a reply to message #332225] Mon, 13 October 2008 09:36 Go to previous message
Suddenly it all becomes clear - thanks for the pointer.
Adrian
Previous Topic:How to add an Annotation (visible in TextEditor and Childs) to a File?
Next Topic:Good resources about implementing Capabilities/Activities?
Current Time: Mon Jul 21 22:18:24 EDT 2025
Powered by FUDForum. Page generated in 0.09293 seconds
