Home » Eclipse Projects » Eclipse Platform » Extending ResourceNavigator
Extending ResourceNavigator [message #332223] Mon, 13 October 2008 02:37 Go to next message
I am extending "org.eclipse.ui.views.navigator.ResourceNavigator" view.
I have modified the behaviour of
org.eclipse.ui.views.navigator.MainActionGroup" to include only those
popup-menu-actions that are required for my view.
But still i am not able to remove "Team, Compare-With, Replace-With"
menu-actions. Is there a way to remove this behavior?
Re: Extending ResourceNavigator [message #332234 is a reply to message #332223] Mon, 13 October 2008 13:17 Go to previous messageGo to next message
I recommend you look into using the CommonNavigator instead.
ResourceNavigator is deprecated.
Zidane wrote:
> Thanks
*new* Common Navigator Framework section in:
3.4RC4 Platform Plugin Developer Guide (Programmer's Guide)
http://help.eclipse.org/ganymede/topic/org.eclipse.platform. doc.isv/guide/cnf.htm
http://dev.eclipse.org/blogs/francis
http://wiki.eclipse.org/Common_Navigator_Framework
http://wiki.eclipse.org/Common_Navigator_Framework_Use_Cases
You have brains in your head.
You have feet in your shoes.
- Dr Seuss, Oh the Places You'll Go
Re: Extending ResourceNavigator [message #332244 is a reply to message #332234] Tue, 14 October 2008 06:54 Go to previous message
> Zidane wrote:
>> Thanks
Thanks a lot Francis...
This is totally new to me i cant wait to explore
Thanks again
Previous Topic:Problem with builders not copying .xml files to bin directory
Next Topic:add file to a project programmatically?
Current Time: Sun Jul 27 07:25:01 EDT 2025
Powered by FUDForum. Page generated in 0.13851 seconds
