Home » Eclipse Projects » Eclipse Platform » Duplicate template proposals prevent automatic insertion
Duplicate template proposals prevent automatic insertion [message #332163] Wed, 08 October 2008 00:34 Go to next message
Hi All,
In a previous version of Eclipse I would design a few Java editor
templates with unique names. Then I would enter just the name e.g.
"templatex", press control + . and the template would automatically get
inserted.
Now, however, the content assist displays a list with two duplicate
entries for my uniquely named template i.e. no automatic insertion.
Is this a bug perhaps?
Rob
Re: Duplicate template proposals prevent automatic insertion [message #332166 is a reply to message #332163] Wed, 08 October 2008 03:22 Go to previous messageGo to next message
Robert Mark Bram wrote:
> Hi All,
> get inserted.
Go and reset the Advanced content assist preferences.
Dani
> Rob
Re: Duplicate template proposals prevent automatic insertion [message #332186 is a reply to message #332166] Wed, 08 October 2008 19:14 Go to previous messageGo to next message
Hi Dani,
Thanks for this. This particular tip did not work, but when I looked at
Advanced content assist preferences I saw that in the top panel, "Select
the proposal kinds contained in the 'default' content assist list", there
were "Template Proposals" and "Template Proposals (Focused)" both
checked. Not knowing the difference, I unchecked the latter and this
problem is solved.
Rob
Re: Duplicate template proposals prevent automatic insertion [message #332191 is a reply to message #332186] Thu, 09 October 2008 04:24 Go to previous message
> Hi Dani,
> at Advanced content assist preferences I saw that in the top panel,
> "Select the proposal kinds contained in the 'default' content assist
> list", there were "Template Proposals" and "Template Proposals
> (Focused)" both checked. Not knowing the difference, I unchecked the
> latter and this problem is solved.
Mmh - clicking 'Restore Defaults' should have done the trick too.
Anyway, good to hear it works again for you.
Dani
> Rob
Previous Topic:(ganymede) Differenting "SDK" from "Platform SDK" in Software Update dialog
Next Topic:ISearchQuery.run(IProcessMonitor) ,how is it get called??
Current Time: Fri Jul 18 23:05:34 EDT 2025
Powered by FUDForum. Page generated in 0.04281 seconds
