Home » Eclipse Projects » Eclipse Platform » Contributing command to popup submenu
Contributing command to popup submenu [message #332159] Tue, 07 October 2008 13:45 Go to next message
Originally posted by: bsv.datatel.com
I have a view. This view has a popup menu registered in the default
fashion, e.g. the popup menu ID is the same as the view ID.
This popup menu has a submenu, contributed as a "menu" under an
"objectContribution" on a legacy "popupMenus" extension point. The
"menu" has a unique ID.
There are a couple items on that submenu which are also contributed via
the popupMenus extension point.
Here's the problem. I have a command that I want to contribute to that
same submenu. I'm trying to use the new "menuContribution" element on
the "org.eclipse.ui.menus" extension point. Specifying the locationURI
to the submenu is where I get stuck. I thought it would be:
locationURI="popup:submenuID"
But it doesn't show on the submenu. If I use the view ID, it shows on
the submenu's parent (the main popup menu for the view), as such:
locationURI="popup:viewID"
This proves that the appropriate handler is active and the command is
enabled.
Help with getting it show up on the submenu?
Ben
Re: Contributing command to popup submenu [message #332172 is a reply to message #332159] Wed, 08 October 2008 08:23 Go to previous messageGo to next message
The menu contributions (org.eclipse.ui.menus) can't see action
contributions, as they're applied first. Action contributions can see
menu contributions however.
You could simply add the same submenu with the same ID (and whatever
necessary visibleWhen clause to make it like an objectContribution)
using org.eclipse.ui.menus, and then it would be there for your command
as well as the popupMenus.
PW
Paul Webster
Re: Contributing command to popup submenu [message #332177 is a reply to message #332172] Wed, 08 October 2008 10:30 Go to previous message
Thanks. That did the trick.
> PW
Previous Topic:Changing Eclipse preferences programmatically
Next Topic:How to contribute to the Eclipse startup spashscreen?
Current Time: Thu Jul 17 12:07:38 EDT 2025
Powered by FUDForum. Page generated in 0.07939 seconds
