Home » Eclipse Projects » Eclipse Platform » Call hierarchy view
Call hierarchy view [message #332154] Tue, 07 October 2008 11:39 Go to next message
I see the Call Hierarchy view, which shows the possible paths to have
arrived at a certain method. This is not quite what I need. I need to see,
while debugging, the call hierarchy that got to this method at this time.
How can this be done?
Re: Call hierarchy view [message #332156 is a reply to message #332154] Tue, 07 October 2008 12:05 Go to previous messageGo to next message
The Debug view will show you your current stack trace (when that thread
is suspended). You need to suspend your thread (breakpoint or using
the toolbar) and then you can see how you got there.
PW
Paul Webster
Re: Call hierarchy view [message #332157 is a reply to message #332156] Tue, 07 October 2008 12:36 Go to previous message
thx
Previous Topic:External tools and Build configuration variables
Next Topic:File pre-delete notification & Persitent properties
Current Time: Fri Jul 18 01:24:27 EDT 2025
Powered by FUDForum. Page generated in 0.24471 seconds
