Home » Eclipse Projects » Eclipse Platform » Re: Command Dropdown in Toolbar
Re: Command Dropdown in Toolbar [message #332131] Mon, 06 October 2008 11:00 Go to next message
Chris wrote:
> I have a (dynamic) set of actions which should be displayed in a
> dropdown menu in the toolbar. The dropdown is intended to be a selection
> between different options. To visualize this, when the user selects an
> entry from the dropdown menu, the text and the image of the main
> dropdown element should be synchronized with the selected action.
> To accomplish this, I've made a dynamic contribution to
> org.eclipse.ui.menus which provides the actions. This
> CompoundContributionItem fills the ToolbarContributionItem also declared
> under org.eclipse.ui.menus.
> My problem is to replace the dropdown's text and image with the
> selection, since the automatically created CommandContributionItem does
> not offer any way to do so after creation. My current workaround is to
> delete the dropdown item and replace it with a new one each time the
> users makes a selection but this is obviously very messy and has further
> drawbacks. Maybe someone has an idea on how this can be accomplished?
> Thank you for your help,
> Chris
Redirected to eclipse.platform.
PW
Paul Webster
Re: Command Dropdown in Toolbar [message #332132 is a reply to message #332131] Mon, 06 October 2008 11:04 Go to previous messageGo to next message
Paul Webster wrote:
> Chris wrote:
>> selection between different options. To visualize this, when the user
>> selects an entry from the dropdown menu, the text and the image of the
>> main dropdown element should be synchronized with the selected action.
>> declared under org.eclipse.ui.menus.
>> does not offer any way to do so after creation. My current workaround
>> is to delete the dropdown item and replace it with a new one each time
>> the users makes a selection but this is obviously very messy and has
>> further drawbacks. Maybe someone has an idea on how this can be
>> accomplished?
>> Chris
In 3.4 (and 3.3), the handler for the main tool item would implement
org.eclipse.ui.commands.IElementUpdater ... a call to
org.eclipse.ui.commands.ICommandService.refreshElements(Stri ng, Map)
from the UI thread provides your active handler with the opportunity to
update icons, text, etc for that UIElement.
PW
Paul Webster
Re: Command Dropdown in Toolbar [message #332149 is a reply to message #332131] Tue, 07 October 2008 04:18 Go to previous message
Originally posted by: novs.gmx.net
Hi again,
I partly solved the problem of setting the text and image of the dropdown
element by retrieving its ToolItem and setting its text/image.
However, two issues remain:
1: During the initialization of the editor, the ToolBar is still empty.
When is the right time to set up the ToolItem on loading?
2: I'd like the dropdown element to always have the same length,
independen from the length of its text. Is there a way to accomplish this?
Chris
Previous Topic:How to know that autocompletion was automatically triggered, and stop it under some condition?
Next Topic:problem with unwanted notifications
Current Time: Mon Jul 21 22:18:48 EDT 2025
Powered by FUDForum. Page generated in 0.04469 seconds
