Re: Getting usage information [message #1765416 is a reply to message #1765400] |
Fri, 09 June 2017 10:18 |
Pierre Guilet Messages: 250 Registered: June 2017 |
Hello Wilberts,
I am sorry to say that Sirius does not provide any native mechanism to do what you want.
Though a way to do that could be to do the following:
You define a service in your odesign taking as parameters two parameters.
Then For each tool defined in your odesign you set a let operation with an expression calling the service with tool information like (aql:myService('toolName','isPaletteTool'))
You do the same for pop-up menu operation.
Then in the called services you have information of what tool is called and from palette or not. So you can log this information wherever you want.
Pierre
Pierre Guilet - Obeo
FUDForum. Page generated in 0.02513 seconds
