| IMarker - problem view and editor [message #331936] |
Mon, 29 September 2008 22:06  |
I have written a new implementation of a debugger and editor for Lua.
I was trying to set an "Error" IMarker in the editor.
I set an IMarker and the marker shows up in the "Problems view" but not in
the editor. How can I get it to appear in both?
Here is the code I set the marker with.
IWorkspaceRunnable editorMarker = new IWorkspaceRunnable() {
public void run(IProgressMonitor monitor) throws CoreException {
IMarker marker =
ResourcesPlugin.getWorkspace().getRoot().
createMarker(IMarker.PROBLEM);
marker.setAttribute(IMarker.MESSAGE, msg);
marker.setAttribute(IMarker.LINE_NUMBER, lineNumber);
marker.setAttribute(IMarker.TRANSIENT, true);
marker.setAttribute(IMarker.SEVERITY, IMarker.SEVERITY_ERROR);
try {
ResourcesPlugin.getWorkspace().run(editorMarker, null);
} catch (CoreException e) {
System.err.println("Some error set marker: " + e);
| Re: IMarker - problem view and editor [message #331972 is a reply to message #331945] |
Tue, 30 September 2008 15:36   |
Thanks for your help.
Can getting the resource be done with static calls to get the resource (I
don't have the IRresource when I am trying to make a marker because I have
only a file name path that is given back from the Lua interpreter).
For example using:
ResourcesPlugin.getWorkspace() ...
In my line break point code, I am given a IWorkBechPart, from which I can
get my text editor:
public void toggleLineBreakpoints(IWorkbenchPart part, ISelection
selection) throws CoreException {
ITextEditor textEditor = getEditor(part);
IResource resource = (IResource)
editorPart.getEditorInput().getAdapter(IResource.class);
But I believe you are referring to the file resource that I have
interpreted to find the Lua syntax error in the editor, correct?
>> not in the editor. How can I get it to appear in both?
>> IMarker marker = ResourcesPlugin.getWorkspace().getRoot().
> This is wrong. You need to create the marker on the resource that's
> shown in the editor.
> Dani
>> try {
| Re: IMarker - problem view and editor [message #331992 is a reply to message #331972] |
Wed, 01 October 2008 06:54  |
> (I don't have the IRresource when I am trying to make a marker because
> I have only a file name path that is given back from the Lua
> interpreter).
> For example using:
> can get my text editor:
Right. At the point you add the marker you need to resolve the correct
resource otherwise it won't show up in the editor.
Dani
>>> IMarker marker =
>> Dani
>>> try {
FUDForum. Page generated in 0.03841 seconds
