Re: Developing distributed application [message #1761204 is a reply to message #1761202] |
Mon, 08 May 2017 21:17 |
yes it is possible to just use existing FBs. But as you noticed it leads to very complex programs. What I would recommend is to develop your own Basic FBs. What has been identified as a good practice to develop basic FBs for each mechtaronik component and then higher level coordinating Basic FBs providing superviory commands for coordinating the lower level basic FBs. This should also reduce the number of communication blocks between the parts.
In the 1.8.4 version mapping of Subapplications is currently disabled as subapplications where a highly experimental feature in this versions which could lead to lost data. We are currently heavily reworking 4diac-ide for version 1.9 where the whole subapplication code has been changed and the old issues should be removed. In the current state of the 1.9 development subapplication mapping is already working. The next step which is still missing is that subapplications are downloaded to the devices.
FUDForum. Page generated in 0.03785 seconds
