Home » Eclipse Projects » Eclipse Platform » Auto-expanding TreeView?
Auto-expanding TreeView? [message #331892] Fri, 26 September 2008 14:51 Go to next message
Originally posted by: rob.brainkandy-dot-org.org
Hello all,
I'm trying to build code that gets an editor's outline to match the editor's
cursor position. I've done a decent job matching behavior of the JavaEditor
(calling treeViewer.setAutoExpandLevel(-1) to expand all levels.)
However, the viewer seems to fail to do that, *unless* I've already manually
expanded that part of the tree.
I've confirmed that I am able to get to the underlying item in the associated model.
Then I have this code:
ISelection newSelection = element == null ? StructuredSelection.EMPTY :
new StructuredSelection(element);
TreeViewer viewer = getTreeViewer();
if (viewer != null) {
viewer.removeSelectionChangedListener(selectionListener);
viewer.setSelection(newSelection, true);
viewer.addSelectionChangedListener(selectionListener);
I see in the TreeViewer.setSelection method is this documentation:
* <b>Currently the <code>reveal</code> parameter is not honored because
* {@link Tree} does not provide an API to only select an item without
* scrolling it into view</b>
* </p>
OK, for me personally, I would want the item to scroll in to view.
Any suggestions?
Re: Auto-expanding TreeView? [message #331898 is a reply to message #331892] Sat, 27 September 2008 00:24 Go to previous messageGo to next message
> editor's cursor position. I've done a decent job matching behavior of the
> JavaEditor (calling treeViewer.setAutoExpandLevel(-1) to expand all
> levels.)
> manually expanded that part of the tree.
Does your content provider return a non-null value from getParent()?
Re: Auto-expanding TreeView? [message #331930 is a reply to message #331898] Mon, 29 September 2008 14:20 Go to previous messageGo to next message
>>levels.)
Yes. (That is, getParent is returning non-nulls.)
Re: Auto-expanding TreeView? [message #332101 is a reply to message #331930] Thu, 02 October 2008 18:23 Go to previous message
>>> the JavaEditor (calling treeViewer.setAutoExpandLevel(-1) to expand
>>> all levels.)
I might be able to debug this, but I wonder if anyone might have a suggestion
about the right place to debug. What might be failing?
Previous Topic:[DataBinding] refreshing values in Tree/validate with ObservableMapLabelProvider
Next Topic:IPluginBase.getLibraries() returning "bin"?
Current Time: Thu Jul 17 10:09:41 EDT 2025
Powered by FUDForum. Page generated in 0.29481 seconds
