Re: all values shows N/A [message #1760193 is a reply to message #1760095] |
Mon, 24 April 2017 13:07 |
I guess that you are using 1.8.4, at least I've seen this issue several times in 1.8.4. Maybe restarting 4diac-ide and forte helps. In case it does not help, maybe try the 1.9.0.M1 there it should work again.
Re: all values shows N/A [message #1760215 is a reply to message #1760193] |
Mon, 24 April 2017 16:04 |
hi the problem is that you can only monitor FBs which are mapped to a FORTE device. The FBs you've selected are FBs mapped to FBRT from Holobloc which does not support our monitoring protocol.
Re: all values shows N/A [message #1760820 is a reply to message #1760809] |
Wed, 03 May 2017 09:57 |
This is very strange. i would not recommend to use 1.6.2. Monitoring normally works in the 1.8.3 and all in all 1.8.3 is much more stable and has a greatly improved usability. So It would be really interesting via it is not working for you.
FUDForum. Page generated in 0.05228 seconds
