Home » Eclipse Projects » Eclipse Platform » Tycho build 0.3.0-DEV-1572
Tycho build 0.3.0-DEV-1572 [message #331816] Tue, 23 September 2008 15:50 Go to next message
Originally posted by: igor.ifedorenko.com
New Tycho build 0.3.0-DEV-1572 has been deployed to
repository.sonatype.org and you can download distribution from [1].
This build comes packaged with newer version of maven 3.0, which
supposed to fix problems with proxy configuration.
New and noteworthy changes in Tycho itself (in no particular order)
* Added support for pack200
* Added support for signed bundles
* Tycho will properly generate multiple nested JARs as defined
in build.properties file
* Tycho will properly package bundles with existing nested JARs
* Fixed number of problems running unit tests in OSGi runtime
We also setup continuous build of tycho integration tests which we run
against Eclipse 3.2, 3.3 and 3.4. Look for tycho-its* jobs on our hudson
instance [2].
[1]
http://repository.sonatype.org/service/local/repositories/ty cho-pseudo-releases/content/org/codehaus/tycho/tycho-distrib ution/0.3.0-DEV-1572/
[2] http://ci.sonatype.org/view/Tycho/
m2e/tycho team
Re: Tycho build 0.3.0-DEV-1572 [message #331817 is a reply to message #331816] Tue, 23 September 2008 15:51 Go to previous message
Sorry, wrong newsgroup.
Previous Topic:File hiding in perspectives
Next Topic:[Databinding] using ValidationStatusProvider to link external validation framework
Current Time: Wed Jul 16 00:43:28 EDT 2025
Powered by FUDForum. Page generated in 0.26575 seconds
