Home » Eclipse Projects » Eclipse Platform » How to access toolbar button
How to access toolbar button [message #331803] Tue, 23 September 2008 04:31 Go to next message
How can i change the state of the button (in toolbar and menubar
respectively) using selectionChanged(IAction..,ISelection) Method..or any
other way?All buttons should be enabled in the start. The "save" button
should get disabled on clicking "perform" and should be enabled again on
clicking "reset" button.
The plugin.xml looks like follows:
<extension
point="org.eclipse.ui.actionSets">
<actionSet
label="JSDiag Action Set"
visible="true"
id="JSDiagnosis.actionSet">
<menu
label="JSDiagnosis"
id="jsdiagMenu">
<separator
name="jsdiagGroup">
</separator>
</menu>
<action
tooltip="Save task"
label="Save"
icon="icons/save.gif"
class="jsdiagnosis.actions.SaveAction"
toolbarPath="ToolGroup"
menubarPath="jsdiagMenu/MenuGroup"
id="jsdiagnosis.actions.SaveAction">
</action>
<action
tooltip="Perform task"
label="Perform"
icon="icons/perform.gif"
class="jsdiagnosis.actions.PerformAction"
id="jsdiagnosis.actions.PerformAction">
</action>
<action
tooltip="Reset"
label="Reset"
icon="icons/reset.gif"
class="jsdiagnosis.actions.ResetAction"
id="jsdiagnosis.actions.ResetAction">
</action>
</actionSet>
</extension>
thanks,
sana.
Re: How to access toolbar button [message #331812 is a reply to message #331803] Tue, 23 September 2008 08:45 Go to previous message
When your selectionChanged(*) method is called, you can call
action.setEnabled(true/false)
If you have 3 buttons that are supposed to work together, you'll need to
have them communicate through your application/plugin model somewhere.
PW
Paul Webster
Previous Topic:Custom plugin will not install
Next Topic:File hiding in perspectives
Current Time: Mon Sep 01 02:43:15 EDT 2025
Powered by FUDForum. Page generated in 0.10014 seconds
