Replace plugin'ed HTML file with a new one from a fragment [message #331716] |
Thu, 18 September 2008 04:17 |
I've got a plugin named com.xyz.plugin
this plugin contains HTML files (from the doc)
I would like to adapt a few of these HTML files using a fragment, it's not a localization issue as I want to replace the HTML file for any language in the runtime environment.
I created a
com.xyz.fragment with com.xyz.plugin host.
The problem I'm facing is that as long as the html file exists in com.xyz.plugin the fragment one is not used. If I delete the com.xyz.plugin HTMl file, then the fragment one is used.
Is there a way to replace a plugin'ed file with a fragment one just as we can do for the Java classes or is that a limitation ?
Thanks for your help.
Cédric
FUDForum. Page generated in 0.02877 seconds
