Home » Eclipse Projects » Eclipse Platform » How to provide the initial checked state for the items of a TableViewer with SWT.CHECK?
How to provide the initial checked state for the items of a TableViewer with SWT.CHECK? [message #331712] Wed, 17 September 2008 23:41 Go to next message
I tried search any snippets or articles related to this topic, but I have
not found.
Currently, I do an iteration to initialize the check state for each item
after setInput();
public void reloadDataIntoView(){
theTableViewer.setInput(getModel());
for (TableItem item: theTableViewer.getTable().getItems()) {
ModelType data = (ModelType)item.getData();
item.setChecked(data.isChecked());
But I think, perhaps somebody could tell me there is other better methods to
achieve this purpose.
Thanks!
Yau. K.J.
Re: How to provide the initial checked state for the items of a TableViewer with SWT.CHECK? [message #331713 is a reply to message #331712] Thu, 18 September 2008 02:25 Go to previous message
There's not API for this though it might make sense. Could you file a
bug against Platform/UI and cc me on the bug.
In the meanwhile you could subclass CheckedTableViewer and overload
protected ViewerRow internalCreateNewRowPart(int style, int rowIndex) {
super.internalCreateNewRowPart(style|SWT.CHECK, rowIndex)
This internal API and CheckedTableViewer says you should not subclass
but its the only possibility I currently see without revisiting the
whole table items. Please not that this method is called whenever a new
item is created.
Tom
Yau K.J. schrieb:
> not found.
> after setInput();
> Thanks!
> Best regards,
> Yau. K.J.
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Previous Topic:Re: how to get out of "NLS unused message" in log file
Next Topic:Hyperlinks don't go away
Current Time: Sun Aug 31 02:33:52 EDT 2025
Powered by FUDForum. Page generated in 0.03687 seconds
