Home » Eclipse Projects » Eclipse Platform » Hyperlinks don't go away
Hyperlinks don't go away [message #331711] Wed, 17 September 2008 14:27 Go to next message
Hi All,
I'm trying to add support for a new type of hyperlinks in my editor...
Everything seems good. I have HyperlinkDetector that extends the
AbstractHyperlinkDetector, I have my own Hyperlink class that implements
the IHyperlink interface. Hyperlinks actually work everything is great
except...
Sometimes the blue colored text with the underline does not go away after
the first time i pass with my mouse (holding Ctrl) over the word. I later
discovered that his only happens if there is no space after the word that
becomes a link.
For example if i have:
<code>
my_hyperlink1(one or more spaces after it)
my_hyperlink2(no spaces after it, just new line)
</code>
my_hyperlink2 stays colored after the first time i pass over it (sounds
like a bug) and my_hyperlink1 doesn't.
I haven't defined my own HyperlinkPresentation... I'm using the default
one...
Am I doing something wrong.
Nikola
Re: Hyperlinks don't go away [message #331714 is a reply to message #331711] Thu, 18 September 2008 03:08 Go to previous message
Nikola Borisov wrote:
> Hi All,
> implements the IHyperlink interface. Hyperlinks actually work
> everything is great except...
> after the first time i pass with my mouse (holding Ctrl) over the
> word. I later discovered that his only happens if there is no space
> after the word that becomes a link.
> <code>
> </code>
> (sounds like a bug) and my_hyperlink1 doesn't.
> default one...
Don't know ;-)
It might be a bug. The best you can do is create a little demo plug-in
and attach it to a bug report (Platform Text,
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Platform).
Dani
> Nikola
Previous Topic:How to provide the initial checked state for the items of a TableViewer with SWT.CHECK?
Next Topic:Replace plugin'ed HTML file with a new one from a fragment
Current Time: Mon Jul 21 23:57:42 EDT 2025
Powered by FUDForum. Page generated in 0.24240 seconds
