Home » Eclipse Projects » Eclipse Platform » can the P2 dropins directory be used to try different releases of a plugin/feature ?
can the P2 dropins directory be used to try different releases of a plugin/feature ? [message #331701] Wed, 17 September 2008 06:08 Go to next message
I installed some features (M2T 0.9.1RC2 )in the dropins folder of an SDK
3.4.1RC3.
As that M2T release fails to work for me (with an NPE) I tried to go
back to my older-and-tried 0.9.0
So I shut down the platform, moved the m2t..091rc2... directory I had
under dropins and unzipped a 090 there
On restart the M2T contributions can't be seen (wizards/editors/run
configurations ... all gone). From the software updates menu the
features are all listed and there are no messages on the consoles.
Funnily enough I cannot even revert to 091RC2, by deleteing the 090
directory and reinstating the 091RC2. Still the contributions cannot be
seen.
Starting the platform with -clean does not help either.
I can only restart unzipping a new fresh SDK and re-add all my plugins
stack (emf/wst/m2t/svn .... again!!! very annoying as some need to be
pulled from a web update site etc.).
So how is one supposed to use the dropins to try different releases ???
If it is possible at all !!!
Re: can the P2 dropins directory be used to try different releases of a plugin/feature ? [message #331725 is a reply to message #331701] Thu, 18 September 2008 10:06 Go to previous message
> 3.4.1RC3.
> seen.
Redirecting.
PW
Paul Webster
Previous Topic:Add Marker Performance
Next Topic:Re: Databinding Multiple Items in an Table
Current Time: Sun Aug 31 01:20:54 EDT 2025
Powered by FUDForum. Page generated in 0.04424 seconds
