4DIAC: Use of layers in EMB_RES editor [message #1757945] |
Wed, 22 March 2017 08:41 |
I want to suggest new way to edit EMB_RES with use of layers without many Map\Unmap actions.
For example, we have system with many apps and FBs from these apps mapped to one EMB_RES.
It turns out that it's very difficult to work with FBs from all apps in one window.
I suggest to use of layers when every app will be a layer.
For example if I want to view FBs from only one app I activate only one layer.
Re: 4DIAC: Use of layers in EMB_RES editor [message #1757966 is a reply to message #1757945] |
Wed, 22 March 2017 11:07 |
Thank you for this suggestion. It sounds very interesting. For 1.9.0 we have done a first cleanup of the resource editor and removed the the top application part as a whole as for big applications the mapping is easier and more efficient to map via the context menu. But showing only application parts in resources is an interesting addition.
I think in your setup haveing more resources could be an interesting option. Have you tried that. Furthermore I think the new subapplication model will be good for you.
One final issue i have with your overlay, if I want to connect two application sthis will not work which I would find a shortcomming.
Re: 4DIAC: Use of layers in EMB_RES editor [message #1758054 is a reply to message #1757966] |
Thu, 23 March 2017 08:13 |
Quote:I think in your setup haveing more resources could be an interesting option.
Yes, of course. But you need to consider that each resource is a new thread.
Quote:Furthermore I think the new subapplication model will be good for you.
We decided to wait for the release 1.9.0 )
Quote:One final issue i have with your overlay, if I want to connect two application sthis will not work which I would find a shortcomming.
I suggest to use of layers when every app will be a layer. And I will be able to activate any of the layers in any combination (any one, any two or every layers).
Re: 4DIAC: Use of layers in EMB_RES editor [message #1758060 is a reply to message #1758054] |
Thu, 23 March 2017 08:28 |
Lik Lik wrote on Thu, 23 March 2017 08:13Quote:I think in your setup haveing more resources could be an interesting option.
That is one of the reasons I suggeted that. As it may make your applications more reactive as FBs from different applications will not block each other. But on resource limted devices the resoruce needs of a thread can be an issue.
We hope to have soon a next milestone release which can be used for users like you.
Good point. As said in my post i like your suggestion. But not sure that we'll be able to already consider it for 1.9.0 but an improved resource editor is definitly on our midterm roadmap.
FUDForum. Page generated in 0.02953 seconds
