Home » Eclipse Projects » Eclipse Platform » Showing perspective-defined wizards in custom navigator
Showing perspective-defined wizards in custom navigator [message #331648] Mon, 15 September 2008 12:38 Go to next message
I've created a perspective that defines new wizard shortcuts. These appear
in the standard navigator view. However, I've also created a custom
navigator view, which defines its own content and label providers. The new
wizard shortcuts don't appear in this navigator view.
Is there any way I can make the custom view pick up on the wizards defined
in the perspective?
Adrian
Re: Showing perspective-defined wizards in custom navigator [message #331891 is a reply to message #331648] Fri, 26 September 2008 12:46 Go to previous message
The commonWizard element of the navigatorContentProvider should do it.
Francis
> appear in the standard navigator view. However, I've also created a
> custom navigator view, which defines its own content and label
> providers. The new wizard shortcuts don't appear in this navigator view.
> defined in the perspective?
> Adrian
*new* Common Navigator Framework section in:
3.4RC4 Platform Plugin Developer Guide (Programmer's Guide)
http://help.eclipse.org/ganymede/topic/org.eclipse.platform. doc.isv/guide/cnf.htm
http://dev.eclipse.org/blogs/francis
http://wiki.eclipse.org/Common_Navigator_Framework
http://wiki.eclipse.org/Common_Navigator_Framework_Use_Cases
You have brains in your head.
You have feet in your shoes.
- Dr Seuss, Oh the Places You'll Go
Previous Topic:[CommonNavigator] Setting a IElementComparer
Next Topic:Converting JEE package installation to Eclipse Classic
Current Time: Sat Jul 26 09:30:42 EDT 2025
Powered by FUDForum. Page generated in 0.05209 seconds
