| Radio Buttons in Dynamic Menu [message #331563] |
Thu, 11 September 2008 14:37  |
<html>
<head>
</head>
<font face="Helvetica, Arial, sans-serif">Hi,<br>
<br>
I am trying to put a <u>dynamic menu</u> in my Common Navigator View.<br>
I want this menu to have 5 choices - radio buttons. My NON-WORKING :)
code is below.<br>
The elements are apearing in the dynamic menu, but the RADIO buttons
behaviour is not working properly (cause the black bullet is not
showing)<br>
Does anybody knows why?<br>
<br>
Thank you so much,<br>
AR<br>
</font><br>
public class <b>MMFEListContributionItem </b>extends
CompoundContributionItem {<br>
<br>
public static final String MMFE_LIST_CI_ID =
"com.csw.macs.core.SetMMFEContribution";<br>
private static final String SET_MMFE_COMMAND_ID =
"setMMFEInConfigContentsViewCommand";<br>
<br>
@Override<br>
protected IContributionItem[] <b>getContributionItems</b>() {<br>
<br>
ConfigurationInstantiation ci =
ConfigurationContentsNavigator.getSelectedCI();<br>
Map<String, Object> parameters = new HashMap<String,
Object>();<br>
if (ci != null) {<br>
ArrayList<IContributionItem> contribItems = new
ArrayList<IContributionItem>();<br>
//Start group marker<br>
contribItems.add(new GroupMarker("MMFEs_START"));<br>
for (MmfeInstance mmfei : ci.getMmfeinstances()) {<br>
<b>ccipSetMMFE </b>= new
CommandContributionItemParameter(PlatformUI.getWorkbench()<br >
.getActiveWorkbenchWindow(), MMFE_LIST_CI_ID,
SET_MMFE_COMMAND_ID,<br>
CommandContributionItem.STYLE_PUSH);<br>
// set the command id<br>
ccipSetMMFE.commandId = SET_MMFE_COMMAND_ID;<br>
ccipSetMMFE.style = <b>CommandContributionItem.STYLE_RADIO</b>;<br>
// set the parameters for this command<br>
parameters.clear();<br>
parameters.put("mmfeId",
Integer.toString(mmfei.getId()));<br>
ccipSetMMFE.parameters = parameters;<br>
// set the label<br>
ccipSetMMFE.label = mmfei.getName();<br>
contribItems.add(new CommandContributionItem(<b>ccipSetMMFE</b>));<br>
}<br>
return contribItems.toArray(new IContributionItem[] {});<br>
} else<br>
return new ContributionItem[0];<br>
}<br>
<br>
}<br>
<br>
<br>
</body>
</html>
FUDForum. Page generated in 0.03421 seconds
