Re: haw add pool in BMPT [message #1754910 is a reply to message #1754909] |
Thu, 23 February 2017 21:05 |
Delacyr Ferreira Messages: 20 Registered: February 2016 |
When you are building a BPMT (see this example), it is based in two or more business process model, because you need to map communalities (common activities at your domain) and variabilities (what varies) in your BPMT, do you understand this idea? You can set as VarPoint type elements only in task and subprocess, and their variants must be the same type. The connection has to be made from variant to varpoint.
Tasks with VarPoint type must contain variant Tasks
DataInput with VarPoint type must contain variant DataInput
Your url doesn't work properly for me. Try again.
If you want know which element to use for your purpose, you must consider to review BPMN documentation. http://www.omg.org/spec/BPMN/2.0/PDF
[Updated on: Thu, 23 February 2017 21:26] Report message to a moderator
FUDForum. Page generated in 0.03592 seconds
