Home » Eclipse Projects » Eclipse Platform » Editor status info placement
Editor status info placement [message #331494] Wed, 10 September 2008 07:21 Go to next message
Originally posted by: bullet.magnet.example.com
I'm using Eclipse 3.4.0 Build id: I20080617-2000 and CDT 5.0.0.200806171202
with a multi-monitor setup. The source code window is on the primary (left)
monitor and everything else (Project Explorer, Call hierarchy, Type
Hierarchy, debug, etc) is on the secondary (right) monitor. The only
annoyance with this setup is that the status bar display of
linenumber:column (visible when the editor has the focus, together with the
Writable/Readony and Inser/Overwrite indicators) is "right justified" so it
ends up on the right monitor. Is there a way to push it to the left?
Or do I have to write a plugin which takes up a configurable space on the
status bar (none of the status bar elements are resizable).
Life is complex, with real and imaginary parts.
Re: Editor status info placement [message #331496 is a reply to message #331494] Wed, 10 September 2008 08:12 Go to previous message
One thing you could do is keep the whole window on the left side and
detach the views you want and move them to the right screen.
Dani
Previous Topic:Restart eclipse from command line
Next Topic:On size change of Statusline contribution item
Current Time: Sat Jul 26 09:28:45 EDT 2025
Powered by FUDForum. Page generated in 0.04238 seconds
