Home » Eclipse Projects » Eclipse Platform » How to Force a redraw of the Editor
How to Force a redraw of the Editor [message #331491] Wed, 10 September 2008 04:38 Go to next message
I am using a custom editor. I have some preference that change the Editor's UI. I want to be able to force the editor to redraw when those options are selected (when the apply button in the preference page is selected for example)
Re: How to Force a redraw of the Editor [message #331492 is a reply to message #331491] Wed, 10 September 2008 05:59 Go to previous messageGo to next message
What kind of editor?
Dani
Re: How to Force a redraw of the Editor [message #331582 is a reply to message #331492] Fri, 12 September 2008 03:30 Go to previous messageGo to next message
Well unfortunately it's not a text editor. As i said it's a custom editor that has several Composites in it with tables in them. I have created a preference page that has the options to hide or show the Composites. I want to force the editor to redraw when the Apply button is pressed. The editor is itself a Composite with a FormLayout set. I am invoking the Parent composite's redraw() as well as the redraw() methods of all the child Composites. I've found out something else as well. The redraw() methods are actually doing something the changes are there, but become visible only if i resize the parent Composite. I was wondering how is it posible to invoke the same mechanism that repaints the parent Composite without having to resize it?
Peter
Re: How to Force a redraw of the Editor [message #331602 is a reply to message #331582] Fri, 12 September 2008 09:47 Go to previous messageGo to next message
> resize it? Thanks, Peter
I don't think you want to use redraw() at all, that is pretty low-level.
Since you're using layouts (smart man), you can just call layout() on
the parent Composite(s) that contain the ones you've shown/hidden.
Hope this helps,
Eric
Re: How to Force a redraw of the Editor [message #331609 is a reply to message #331602] Fri, 12 September 2008 15:44 Go to previous message
Thanks, that helped :)
Previous Topic:startup ganymede slows down after renaming some plug-in projects
Next Topic:Tool to edit "solo" fragment in PDE ?
Current Time: Fri Jul 18 17:06:45 EDT 2025
Powered by FUDForum. Page generated in 0.04627 seconds
