Home » Eclipse Projects » Eclipse Platform » extension points without OSGi?
extension points without OSGi? [message #331490] Wed, 10 September 2008 04:10 Go to next message
Is it possible to have the Eclipse extension points work (i.e. find&load
extensions) without starting OSGi? This would be useful to expose a set of
plugins as a library of components, to a standard Java application not
running inside an OSGi container.
David
Re: extension points without OSGi? [message #331535 is a reply to message #331490] Thu, 11 September 2008 09:18 Go to previous message
David Michonneau wrote:
Yes, it is possible to run a java app that uses the IExtensionRegistry.
See
http://dev.eclipse.org/newslists/news.eclipse.technology.equ inox/msg03599.html
and
http://dev.eclipse.org/mhonarc/newsLists/news.eclipse.platfo rm/msg67801.html
PW
Paul Webster
Previous Topic:Is there a "Workbench User Guide" for RCP?
Next Topic:can dynamic menus exist in global menubar?
Current Time: Fri Jul 18 23:21:14 EDT 2025
Powered by FUDForum. Page generated in 0.02632 seconds
