Home » Eclipse Projects » Eclipse Platform » Is there a Feature Cleanup tool?
Is there a Feature Cleanup tool? [message #331458] Mon, 08 September 2008 11:52 Go to next message
I have installed an M-Build for RSE to get a fix for a problem I reported.
Now I have duplicate features laying around in my system. Eclipse does a
fine job of detecting the current version and loading it, but I would like
to remove the older versions.
Is there a tool that will scrub the eclipse folder removing features that
have newer versions installed?
Michael
org.eclipse.rse.core.source_3.0.1.v200809041200-7Z379EB7sQS9 S4WKJQCC
org.eclipse.rse.core_3.0.0.v20080609-7Z3-EB7sQS9RiVd
org.eclipse.rse.core_3.0.1.v200809041200-7Z379EB7sQS9S4WKJQC C
org.eclipse.rse.dstore.source_3.0.1.v200809041200-7J32DUUEFD F3It2311
org.eclipse.rse.dstore_3.0.0.v20080609-7J3-DUUEFDEyF
org.eclipse.rse.dstore_3.0.1.v200809041200-7J32DUUEFDF3It231 1
org.eclipse.rse.ftp.source_3.0.1.v200809041200-78479_kE77c7Q 8a8S8B
org.eclipse.rse.ftp_3.0.0.v20080609-78478_kE77c7O7W5I55
org.eclipse.rse.ftp_3.0.1.v200809041200-78479_kE77c7Q8a8S8B
org.eclipse.rse.local.source_2.1.1.v20080710-7_40AgI99m9d_O
org.eclipse.rse.local_2.1.0.v20080604-7_4-AgI99m9c9S
org.eclipse.rse.local_2.1.1.v20080710-7_40AgI99m9d_O
org.eclipse.rse.sdk_3.0.1.v200809041200-7Q378E8VwNQiAC2kb_J- iMhXGbz-
org.eclipse.rse.ssh.source_2.1.1.v20080714-7830_kE77c7V8M
org.eclipse.rse.ssh_2.1.0.v20080604-783-_kE77c7U7M
org.eclipse.rse.ssh_2.1.1.v20080714-7830_kE77c7V8M
org.eclipse.rse.telnet.source_2.1.0.v20080604-6678AgI99m9W9W 5I55
org.eclipse.rse.telnet_2.1.0.v20080604-6678AgI99m9W9W5I55
org.eclipse.rse.terminals.source_0.1.1.v200809041200-2229sB7 EO_T9R5C6B3457
org.eclipse.rse.terminals_0.1.0.v20080610-22-9sB6EO_O8X2842
org.eclipse.rse.terminals_0.1.1.v200809041200-2229sB7EO_T9R5 C6B3457
org.eclipse.rse.useractions_1.1.0.v20080604-21-8s733I3E3A
org.eclipse.rse_3.0.0.v20080609-7H3-8qfbaJJZCz-G-QT8RWUC6
org.eclipse.rse_3.0.1.v200809041200-7H358qfenEMeUOENHEbY2AqX K8
Re: Is there a Feature Cleanup tool? [message #331459 is a reply to message #331458] Mon, 08 September 2008 12:07 Go to previous messageGo to next message
Micahel,
I don't think there is, no. I'd love to be wrong though...
> Michael
Re: Is there a Feature Cleanup tool? [message #331477 is a reply to message #331458] Tue, 09 September 2008 09:23 Go to previous message
I don't think such a tool exists. However, it is not as simple a task as
it might seem. First of all, OSGi allows for multiple versions of a
bundle (plugin) to be used at the same time. If different plugins depend
on different versions of the same plugin, that has to be supported and
thus you can't just remove the older versions; you would have to verify
that no other plugins are depending on them first, which is not a
trivial task IMO.
Second, I'm pretty sure old versions are kept around to enable the
"revert configuration" feature, which allows you to easily revert your
set of plugins to a previous state (useful in cases where you install
something that you later decide to back out).
Eric
Previous Topic:Ganymede Update Problems
Next Topic:Subclipse on Ganymede, comparison editor fails most of the time?
Current Time: Fri Jul 18 13:20:44 EDT 2025
Powered by FUDForum. Page generated in 0.03778 seconds
