Update manager from command line [message #331384] |
Thu, 04 September 2008 04:22 |
Hi everyone!
I am trying to mirror an update site to a local folder, but unfortunately
I keep getting error messages. I am behind a company firewall, but
updating with the graphical update UI works fine (with the correct proxy
settings).
I tried several update sites and had the same problem with all of them. I
also tried to open the site in the browser which also works.
I am not sure if this really is the problem, but I assume that there is a
problem with the firewall/proxy. Is there a way to set these options in
the command line? Do you have any other ideas what the problem might be?
Thanks in advance!
Christian
Here is the command line:
java -jar plugins/org.eclipse.equinox.launcher_1.0.100.v20080509-1800. jar
-application org.eclipse.update.core.standaloneUpdate -command mirror
-from http://update.eclipse.org/updates/ -to c:\temp -ignoreMissingPlugins
true
This is the error:
!SESSION 2008-09-04 09:58:47.102
eclipse.buildId=I20080617-2000
java.version=1.5.0_06
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_DE
Framework arguments: -application
org.eclipse.update.core.standaloneUpdate -command mirror -from
http://update.eclipse.org/updates/3.0 -to c:\temp -ignoreMissingPlugins
true
Command-line arguments: -application
true
!ENTRY org.eclipse.update.core 4 0 2008-09-04 09:58:48.524
!MESSAGE Unable to access "http://update.eclipse.org/updates/3.0".
!STACK 1
org.eclipse.core.runtime.CoreException: Error parsing site stream.
[Premature end of file.]
at org.eclipse.update.core.Utilities.newCoreException(Utilities .java:223)
at org.eclipse.update.core.Utilities.newCoreException(Utilities .java:254)
org.eclipse.update.core.model.SiteModelFactory.parseSite(Sit eModelFactory.java:93)
org.eclipse.update.internal.core.SiteURLFactory.createSite(S iteURLFactory.java:80)
org.eclipse.update.internal.core.InternalSiteManager.createS ite(InternalSiteManager.java:334)
org.eclipse.update.internal.core.InternalSiteManager.createS ite(InternalSiteManager.java:326)
org.eclipse.update.internal.core.InternalSiteManager.createS ite(InternalSiteManager.java:298)
org.eclipse.update.internal.core.InternalSiteManager.attempt CreateSite(InternalSiteManager.java:222)
org.eclipse.update.internal.core.InternalSiteManager.getSite (InternalSiteManager.java:162)
at org.eclipse.update.core.SiteManager.getSite(SiteManager.java :80)
org.eclipse.update.internal.mirror.MirrorCommand.run(MirrorC ommand.java:78)
org.eclipse.update.standalone.ScriptedCommand.run(ScriptedCo mmand.java:64)
org.eclipse.update.standalone.StandaloneUpdateApplication.ru n(StandaloneUpdateApplication.java:47)
org.eclipse.equinox.internal.app.EclipseAppContainer.callMet hodWithException(EclipseAppContainer.java:574)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:195)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:382)
at org.eclipse.equinox.launcher.Main.main(Main.java:1212)
Caused by: org.xml.sax.SAXParseException: Premature end of file.
com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper. createSAXParseException(Unknown
Source)
com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper. fatalError(Unknown
Source)
com.sun.org.apache.xerces.internal.impl.XMLErrorReporter.rep ortError(Unknown
Source)
Source)
com.sun.org.apache.xerces.internal.impl.XMLVersionDetector.d etermineDocVersion(Unknown
Source)
com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(Unknown
Source)
Source)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(U nknown
Source)
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .parse(Unknown
Source)
at javax.xml.parsers.SAXParser.parse(Unknown Source)
org.eclipse.update.core.model.DefaultSiteParser.parse(Defaul tSiteParser.java:152)
org.eclipse.update.core.model.SiteModelFactory.parseSite(Sit eModelFactory.java:81)
... 28 more
!SUBENTRY 1 org.eclipse.update.core 4 0 2008-09-04 09:58:48.524
!MESSAGE Error parsing site stream. [Premature end of file.]
!STACK 0
Source)
Source)
Source)
Source)
Source)
Source)
Source)
Source)
Source)
!STACK 0
Source)
Source)
Source)
Source)
Source)
Source)
Source)
Source)
Source)
FUDForum. Page generated in 0.08951 seconds
