Home » Eclipse Projects » Eclipse Platform » Plug-in Beginner
Plug-in Beginner [message #331372] Wed, 03 September 2008 17:17 Go to next message
I am writing an eclipse plug-in.
//get the current display, eclipse display
Display currentDisplay = PlatformUI.getWorkbench().getDisplay();
From here I would like to add event listeners to the currentDisplay to
detect any events that happen within eclipse. I am just looking for a
little direction, not the exact program. I mean if someone has the exact
why I'd love to take a look at it.
Thanks in advance,
Jason
Re: Plug-in Beginner [message #331378 is a reply to message #331372] Thu, 04 September 2008 02:03 Go to previous messageGo to next message
Hi Jason,
Which kind of UI events are you really interested in ??
In SWT, depending on the widget you are working on you have a lot of
addXXXListener methods, for example addMouseListener.
These methods are not available on the display but you can acces it on a
Shell.
For example PlatformUi.getWorkbench().getActiveWorkbenchWindow().getShel l()
Hope this can help
Manu
Re: Plug-in Beginner [message #331381 is a reply to message #331372] Thu, 04 September 2008 03:49 Go to previous messageGo to next message
On Wed, 3 Sep 2008 21:17:38 +0000 (UTC), jasoncartercs@gmail.com
(Jason Carter) wrote:
>Hello,
>Thanks in advance,
>Jason
To see EVERY event you have to register an event filter and NOT filter
any event inside. If you just add an event listener you will miss the
filtered events. So use the addFilter(...) method instead of the
addListener(...) method.
Achim
Achim Lörke
Eclipse-Stammtisch in the Braunschweig, Germany area:
http://www.bredex.de/de/news/events.html
Re: Plug-in Beginner [message #331399 is a reply to message #331378] Thu, 04 September 2008 14:08 Go to previous messageGo to next message
I am interested in all the events. I want to be able to capture what a
user is doing. If they clicked on the File Menu, if they debugged the
application, if they are typing text in the editor.
Jason
Re: Plug-in Beginner [message #331407 is a reply to message #331381] Thu, 04 September 2008 22:46 Go to previous messageGo to next message
Could you please give me an example of this?
Re: Plug-in Beginner [message #331416 is a reply to message #331407] Fri, 05 September 2008 04:51 Go to previous messageGo to next message
On Fri, 5 Sep 2008 02:46:07 +0000 (UTC), jasoncartercs@gmail.com
// add a filter for all interesting event, i.e. KeyDown/Up,
// MouseDown/Up, MouseMove, ...
// example for KeyDown
currentDisplay.addFilter(SWT.KeyDown, new Listener(){
public void handleEvent(Event event) {
// log your event, don't modify the event instance!
// you know that this is a KeyDown event, so
// you may call an appropriate logger.
Achim
Achim Lörke
Re: Plug-in Beginner [message #331422 is a reply to message #331407] Fri, 05 September 2008 08:11 Go to previous messageGo to next message
And I'll just add ... use addFilter(*) with care (i.e. don't spend a lot
of time in your handleEvent, and don't use it at all in an eclipse
plugin if you can help it). It filters every event that the Display
sees (so a simple mistake here can render anything that depends on SWT
unusable, flaky, or extremely slow).
PW
Paul Webster
Re: Plug-in Beginner [message #331428 is a reply to message #331422] Fri, 05 September 2008 09:40 Go to previous messageGo to next message
On Fri, 05 Sep 2008 08:11:06 -0400, Paul Webster <pwebster@ca.ibm.com>
>PW
Of course you are right. It is extremely dangerous to use addFilter()
and might introduce some hard to find errors. One has to be very
careful when switching threads in a filter operation and should NEVER
do any syncExec() calls.
But it's the only way to get all events which is a must in certain
debugging or test scenarios (which is our excuse for using filters :-)
Achim
Achim Lörke
Re: Plug-in Beginner [message #331429 is a reply to message #331428] Fri, 05 September 2008 11:26 Go to previous messageGo to next message
Thanks!
I am now able to see when a user clicks on the menu bar in eclipse with
this code.
Display display = PlatformUI.getWorkbench().getDisplay();
//user clicked a menu
Listener armListener = new Listener()
MenuItem item = (MenuItem) event.widget;
System.out.println(item.getText());
//I also do some logging here as well
display.addFilter(SWT.Arm, armListener);
Anyone have an idea on how to get events on the editor?
Re: Plug-in Beginner [message #331451 is a reply to message #331429] Mon, 08 September 2008 08:22 Go to previous message
I am able to get to the editor. If anyone wants to know how I did it just
post here and I can send you the code.
Previous Topic:Ganymede: Annoying JRE warnings
Next Topic:Solution of ContentAssist Problem
Current Time: Sat Jul 26 09:28:40 EDT 2025
Powered by FUDForum. Page generated in 0.05836 seconds
